Home > General Chat > Hillclimb advice
haimesyboi
Member #: 5702
Cornwall
I am planning to run the mini on a couple of the remaining local hillclimbs and sprints mainly to gain some experience and have some fun with the old man as second driver.
We have applied for registration with the local motor club and the MSA nat B licence. as i understand it this is all you need to apply for the events.
I havent got any detailed info on how to determine the correct class. Im thinking C2 because it is modified from the standard production car it was and the capacity increase from the turbocharger.
Has anyone got any tips on how to prepare the car, things the scrutineers like/dont like to see?
cheers
The problem is that a1275 mini with a turbo doesn't really fit into any calss. the rules state that you car must remain in the capacity classit was produced in. so upto 1400cc in the case of a mini. You may be able to argue that the ERA as the class above, but it won't be easy.
The turbo is a 1.4 multiplier, so a 1275 with a turbo will be 1785cc equivalent.
Scutineering wise, as long as you car is not a piece of shit, it shouldn't be a worry. It's pretty easy to comply with the blue book.
haimesyboi
Member #: 5702
Cornwall
Thanks Wil, my blue book hasnt arrived yet i will give it a good read next week.
So the turbo capacity penalty takes it over the 1400cc making it illegible for the production classes?
Im not too worried what class i end up in as i will be racing against the old man really.
Ben H
Member #: 184
Melton Mowbray, Pie Country
You are correct as the mini was never made over 1400cc it can't compete in the 1400 to 2000 class, which is a shame.
With this engine you will be forced into sports libra, I would think. This is a problem as the safety rules are much stricter, as you will see when you get your blue book. You may be able to argue the ERA turbo and get in a limited production class, which would be best.
http://www.twin-turbo.co.uk
george91
Member #: 8932
A question out of interest for Wil or Ben, are you allowed re-bores on your 998 turbos? As it would go over the capacity limit marginally.
carl talbot
Member #: 1323
I'm starting a campaign to get DVLA 'Historic Vehicles' [ ie pre '73] exempted from this ridiculous rule regarding 'must compete in the capacity class it was produced in '
Am getting my local motor club committee involved [5 of who hillclimb classic cars]
and then try and take it to the HSA committee
if there's enough/any support present it to the MSA speed committee
Any thoughts/ support amongst you Mini hillclimbers
novarally
Member #: 8995
Poole, Dorset
Definitely not! I run a turbocharged Vauxhall Nova in the up to 1400cc Modified Production Class, and I have to have liners inside the bores to REDUCE the capacity to 985cc (it's based on the 1200cc Vauxhall block).
I then have Metro Van pistons modified to fit.
carl talbot
Member #: 1323
Did you not sell the car - or are you the new owner ?
Out of interest - why go to all the trouble to run as 1400 mod prod -
Why not turbo and run in 2000 Mod prod ?
Edited by carl talbot on 10th Jul, 2011.
Scruffy
Member #: 328
Seaford Rise, South Australia
Is this the ex Andy Bradley car? If so it was v fast in its day and may still be now?
On 5th Sep, 2011 Vegard said:
novarally
Member #: 8995
Poole, Dorset
I bought the car from Andrew Bradley in 2009, and have been using it since.
It's now much quicker than when Andy had it, but reliability hasn't been so hot, and the engine is currently with him for a rebuild.
It's been giving the Minis a good run for their money at Gurston Down recently, even managed to beat Jim White at the April meeting.
In answer to the other query, you're not allowed to run in hillclimbs/sprints outside of the capacity that was originally available in the range of cars built by the factory.
So as a 2 litre Nova was never made, you can't race in the Production Car categories with the cc equivalent of a 2 litre engine (i.e. a 1400cc with a turbo).
At least that's my understanding of the rules......
Edited by novarally on 10th Jul, 2011.
carl talbot
Member #: 1323
There was a 1600cc version [ petrol and diesel ]
this means you can run in 1400cc - 2000cc class
I was thinking this. The Nova GTE was 1598cc or something similar was it not?
haimesyboi
Member #: 5702
Cornwall
I went to the hillclimb today and met some really nice people, none of the mini boys have ever heard of a mini with a turbo fitted :)
The scrutineers had all left early and nobody had any information on the capacity going over 1400
Is this in the book? if so the ERA was built in the factory or maybe the metro and it could be a good argument
The next round here which i wish to enter is early next month and i doubt i will have the time/funds to meet strict safety requirements, it might be more realistic to run a low boost 998 *oh well*
Ben H
Member #: 184
You can race a metro turbo in the upto 2000cc class as it was made as a 1275 turbo. As has already been stated the nova can run in the up to 2000cc class as it was produced with an engine above 1400cc.
As far as I know we are the only 998cc turbo mini on the hills so if you don't compete at the events we do then you would not have heard of us.
I actually am a member of the Hillclimb abd Sprint Sub committee for the MSA. I can see where you are comming from with the engine capacity rules, but these are long established rules. As has been said many times before, don't build a car and then try to race it in a class, first read the rules and then build a car to the class.
haimesyboi
Member #: 5702
Cornwall
Thanks Ben I accept the rules are there for a reason and its my fault the car was not built with the intentions to race.
I have decided to change to small bore with the current turbo gear to make things easier and just get some track time. Then build something a bit more competitive for next year.
Just for the argument the metro turbo can run in the upto 2000 can a NA metro with a turbo fitted do the same. If so wouldn't it be the same for the ERA and a originally NA mini?
novarally
Member #: 8995
Poole, Dorset
You are completely right of course, my apologies. I'm getting my hillclimb rules well and truly mixed up! (not difficult to do as they are so outdated and complicated).
I've always felt that the Nova needs to be in the under-1400cc Class to be properly competitive, I suspect that a 1400cc turbo version of my current engine would still struggle against the serious 2-litre competitors using Warriors and n/a Cosworth YB motors in Mk.1/Mk.2 Escorts.
Interesting idea though, the weight of the Nova would certainly be in my favour in the 1401-2000cc Class.
Ben H
Member #: 184
Basically the metro turbo was available through normal channels as a 1275 turbo. So any metro can be turboed and run in the upto 2000cc. The ERA is odd as it was not sold directly by austin/rover so the waters become a bit muddied.
In many of the events we go to we beat the upto 2000cc cars in the 998 turbo, so I think a 1400cc turbo nova or mini would be competitive. One of the fastest upto 2000cc cars I have seen is a R5GT Turbo.
novarally
Member #: 8995
Poole, Dorset
[/quote]
In many of the events we go to we beat the upto 2000cc cars in the 998 turbo, so I think a 1400cc turbo nova or mini would be competitive. One of the fastest upto 2000cc cars I have seen is a R5GT Turbo.[/quote]
You're right Ben, I've seen a very quick R5GTT at Gurston previously.
I see on your website there's a photo of you at Gurston, what times have you managed there with the 998 Turbo?
We've not been there with the current spec car, which was 1.5 seconds quicker than the old car at Harewood (and would have gone quicker still if it hadn't broken!).
Best time at Gurston was 37.48 in 2008 with 130 bhp, we have a lot more than that now AND propper tyres!!
novarally
Member #: 8995
Poole, Dorset
36.87 is my best at Gurston, although I have no doubts at all that there's a 35s run in it once I've got it reliable.
Only trouble is Neal Masters keeps going quicker in the KAD Mini!
Look forward to seeing you there in the future.
Colin
