| Home > Technical Chat > Compound charging | |||||||
8th Jul, 2011 at 05:59:33pm
Looking at flow maps for chargers they all seem to be rated in Volume rather than the Mass of turbo maps, so this has got me thinking about what happens when you chuck boost into the input of a supercharger,
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
8th Jul, 2011 at 06:04:02pm
maybe im out of my depth here but to me if the charger is capable of 8 psi then putting 10 psi in, i would of thought the charger would be restrictive then? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
8th Jul, 2011 at 06:26:29pm
That's the way I understand it.
On 8th Jul, 2011 wez said:
maybe im out of my depth here but to me if the charger is capable of 8 psi then putting 10 psi in, i would of thought the charger would be restrictive then? |
8th Jul, 2011 at 07:05:09pm
You have to remember there are 2 different types of supercharger. One is a positive displacement type - like the eaton, the other is aerodynamic - like a turbo only shaft driven.
1425 Posts Member #: 690 Post Whore Norfolk |
8th Jul, 2011 at 07:13:31pm
not Mini related Joe but a good build to read anyway, we have a friend in Califonia running a compound charged Elise that Simon mapped - theres lot of build blogs/video's of it in action - look for Ronin, Franks using the stock M62 + big blower together.
If Carling made Mini engines
8th Jul, 2011 at 07:48:02pm
You're nearly there Joe.
8th Jul, 2011 at 09:32:50pm
John,
8th Jul, 2011 at 09:47:41pm
Erm Joe...
In the 13's at last!.. Just |
8th Jul, 2011 at 10:00:56pm
Yes, but you could do it more efficiently with a turbo alone. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Jul, 2011 at 10:10:43pm
LOL this isnt for mine, I'm perfectly happy with where my compressor efficiency is at 30 psi...
8th Jul, 2011 at 10:17:33pm
So does a supercharger multiply what you put into it then?
9th Jul, 2011 at 10:42:56am
If you have a supercharger with a 2 litres displacement for every two revs of the engine feeding a 1 litre engine, then, ignoring the effects of volumetric efficiency and temperature, you will see around one atmsophere of boost, approx. 15 psi.
520 Posts Member #: 2093 Post Whore Grenoble, France |
21st Jul, 2011 at 10:42:35am
Not sure the compressor is able to keep very high pressures. It would leak.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
831 Posts Member #: 908 Post Whore gateshead |
21st Jul, 2011 at 10:56:46am
my eaton m90 has a displacement of 1ltr per revolution and on a 1330 it kicked out 16psi. balls to the blower!!!
21st Jul, 2011 at 01:17:12pm
I had a Saab 93 as a hire car this week. It was 1.9 TTid. Under the bonnet were two turbos, one tiny little one and then one normal sized one. I could not work out the plumbing though but I don't think that they were compound. Quite fancy though and never off boost. (oh its a fiat engine apparently) http://www.twin-turbo.co.uk
21st Jul, 2011 at 04:03:32pm
Staged turbos are getting common. But they never use an I/C between two turbos, the goal is to smooth the torque curve and not to make more power.
