| Home > Help Needed / General Tech Chat > on the way home from avon, i developed what sounded like a set of straight cut drops :S | |||||||
10th Jul, 2011 at 05:24:42pm
Journeying home, i started hearing a ridiculously whiny noise, i thought it may have been gav(madcatsminis) behind me at first, but when i rolled my windows up it got louder, now it doesnt matter what gear im in or neutral, and whether or not the clutch is depressed, but the noise seems to follow the revs, and it sounds like its coming from the drivers side. My clutch was slipping like a shit on the last run down the quarter but the lights buggered up so it didnt matter anyway. But any suggestions on what to start looking at?
10th Jul, 2011 at 06:06:34pm
Idler or primary gear would be a good place to start looking. |
10th Jul, 2011 at 06:18:55pm
If it is ill be glad, as ive got spares from the short engine i bought, gotta have a look at the clutch anyway to see whats up. hopefully its a cheap fix cos im screwed if it isnt :/ On 26th Jan, 2012 Tom Fenton said:
10th Jul, 2011 at 07:56:24pm
How were the dampers?!? On a slightly different note... On 7th Nov, 2011 apbellamy said:
10th Jul, 2011 at 08:28:16pm
If its screeching if the clutch is in or out, then it;s unlikely to be transfer gears. Perhaps your water pump or alternator bearings are giving up?
10th Jul, 2011 at 08:56:42pm
Dampers were great, its like driving a different car. It doesnt happen in neutral at idle, but if you leave it in neutral and rev you can hear it, and its far worse of a noise when under load. My alternator and waterpump are practically brand new so it isnt those On 26th Jan, 2012 Tom Fenton said:
10th Jul, 2011 at 10:15:15pm
Collapsed first motion bearing in the gear box. We broke the one in the van last year at Avon. the S/c drops disguised the noise.
10th Jul, 2011 at 10:22:29pm
On 10th Jul, 2011 Carlzilla said:
now it doesnt matter what gear im in or neutral, and whether or not the clutch is depressed If it makes the noise on your driveway doing zero mph with the clutch pressed, and perhaps with it in any gear to be sure, then it can't be gearbox related. On 17th Nov, 2014 Tom Fenton said:
10th Jul, 2011 at 11:10:19pm
Thats what i thought, but why would the drops be making that noise? Im not going to be using the car until ive sorted it anyway. Going to start by sorting the clutch because it needs doing anyway, then check and probably replace the drops for the spare ones i have, if that doesnt cure it it'll have to be a gearbox off job :( On 26th Jan, 2012 Tom Fenton said:
10th Jul, 2011 at 11:11:51pm
11th Jul, 2011 at 06:23:46pm
I think i found the noise.
282 Posts Member #: 1404 Senior Member The Netherlands |
11th Jul, 2011 at 09:23:04pm
Well a cheap fix there is nothing wrong with a A-series that a turbo can't fix.
