Home > General Chat > Avon - The Damage
Got the engine apart and in pieces last night (cheers rich, if you're reading)
The damage is as follows:
1) Number 4 big end knackered. Rod for the bin, crank is ok.
2) Number 4 exhaust cam follower destroyed and a bent push rod, cam ok.
3) Primary gear bush knackered.
All seems to have been caused by excessive heat, reason for this is so far unclear, it's run perfectly until now.
Should all be back together for Harewood in august.
I didn't realise you had problems - just saw the car back on the trailer mid afternoon.
Damage isn't too bad.........
oooh commiserations ..avon this year was a war of attrition.
I'm getting worried about the van now! lol
Bad times. At least you have a spare push rod...
EDIT:
The van is fine, most of it made it all the way home and most of the damage is fixed...
Edited by apbellamy on 12th Jul, 2011.
In reality the damage is nowt, no machining required, just a few bits.
And I'm sure I'll sort the heat issue.
wil look into ZDDP buddy PRONTO!!!!
hell mate sorry to hear that, i didn't realise you had issues. I think he uses Millers Benross and that has enough in!
Edited by Miniwilliams on 12th Jul, 2011.
i would be upping the dose to the max matt
Well I think as you know about oils mate, you better tell Millers Oils what to use in there oil then he he :) with the best respect *wink*
wez
Member #: 9271
Stoke on Trent
Whats ZDDP?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
On 13th Jul, 2011 wez said:
Whats ZDDP?
It's the sound that happens when you pull your trouser zip up.
wez
Member #: 9271
Stoke on Trent
*happy*
Whats ZDDP?
no wez ,
ZDD is the zip sound ,
ZDDP is the zip sound plus the edge of your flesh bungee getting caught in the teeth of the zip. *surprised*
Thanks Robert. Was going to have a sausage sandwich for lunch....
*Rofl!*
Oh robert you and your willy analogies!
I learned some corkers at Avon this year.
I use Millers CTV. Oil was not the issue it was lack of cooling.
wez
Member #: 9271
Stoke on Trent
I now know what it is, i asked google. But it didnt mention fore skin any where :-S lol
Do you have an oil temp gauge? I would be very surprised if the oil got too hot on a drag weekend.
Perhaps related to this? See Sprockets posts about heat dissipation. I think he may just have a point.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=430302
Am I right in saying that the 998 crank and rods are slightly less substantial in their construction (mass)? You are pushing more power than the majority of big bore turbo's on here. Could the combination of this and your lightweight clutch, along with plenty full bore drag starts be dumping loads of heat into that end of the crank?
Edited by John on 13th Jul, 2011.
no way the oil will get too hot, we have an oil temp on the Don, and it never moves off the stop
I would be looking at the coolant flow around No. 4.
It got to max 75 deg at the weekend.
Fair point. I think I read something in minimag recently about 998's having poor cooling over that side of the block? I think they blocked off a couple of holes over no.1?
eden7842
Member #: 8852
leicestershire
i read that too. they did that along with the water pump grind hole trick.
BUT form how it read to me it didont seem like it was a tried and tested technique
