| Home > General Chat > 2 way 12v linear actuators. | |||||||
13th Jul, 2011 at 08:55:45pm
Does anyone know a good supplier of actuators?
![]() 902 Posts Member #: 111 Post Whore Loughborough |
13th Jul, 2011 at 09:39:26pm
What you building? Sounds intriguing. |
13th Jul, 2011 at 09:57:28pm
I am just planning for the moment but i need to know that i can get the actuators and that they are not vastly out of my price range before i spend more time working out the finer details and putting it into practice.
13th Jul, 2011 at 11:37:45pm
maplin, 2 wire central door locking servo/solenoids, you would need two for what you require. turbo 16v k-series 11.9@118.9 :)
14th Jul, 2011 at 01:21:03am
F = ma
14th Jul, 2011 at 09:44:56am
Thanks Rod. Its abit clearer now and at least i can work it out. Not a bad guess up top though!!
14th Jul, 2011 at 11:53:53pm
there plenty man enough and when not engaged can be easily moved back and forth by a spring. tbo though for your intedned use i would think pneumatics would be better? or vacuum to be more precice. turbo 16v k-series 11.9@118.9 :)
15th Jul, 2011 at 11:44:49am
I had thought of pneumatics although not on the vacuum side of things. It does sound like a very good idea in principle as there are plenty of options for pneumatic actuators and possibly quite cheap if you could make say a decent wastegate actuator work well.
15th Jul, 2011 at 07:27:32pm
either a 2 way pneumatic ram or 2 1 way rams with biasing springs to suit :) if the gearbox input already self centres then a single 2 way ram and a pair of 2 way solenoids is all you need, and a vacuum accumulaor ofcourse.
