| Home > Help Needed / General Tech Chat > Crank binding | |||||||
16th Jul, 2011 at 08:03:54am
This is a new one to me.....
16th Jul, 2011 at 08:08:22am
i had this when i first built the engine for the Don, it was the centre main that had distorted,
16th Jul, 2011 at 09:39:20am
Are you building it in an ice cave? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Jul, 2011 at 10:44:11am
I have had similar when installing one of Carl's 1" CMSs the wrong way up in a moment of brain fade.
16th Jul, 2011 at 10:47:30am
I was being serious by the way? Is it really cold at the moment? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Jul, 2011 at 05:20:51pm
I have come across this a few times and its either down to the center main strap, cap dowels, or the crank run out (bent).
16th Jul, 2011 at 05:23:12pm
Regarding the mains dowels, the swiftune billet ones are very good, pricy at 15 quid, but worth it IMO as they seem a bit snugger than std ones. On 28th Aug, 2011 Kean said:
16th Jul, 2011 at 06:17:46pm
i have had simlar problems the dowells are the culprit
16th Jul, 2011 at 06:28:06pm
It could be that who ever line borewd it did not have the mains bolts torqued up fully, thus boring a circular hole when the cap is not fully clamped , then when you apply the full 60 lbs it nips down,
