Home > Help Needed / General Tech Chat > Gearbox Like Butter
carts60
Member #: 9335
Bromley, SE London
I'v been rebuilding the gearbox slowly over the past week or so with relative success, apart from breaking a bearing which cost £40 to replace and today I started to put it all back together.
Everything was going swimmingly until the 3rd motion bearing retainer. Was going round each of the three bolts slowly doing each up so as to not crack the casing by too much pressure in one spot over another.
Then, doing the third bolt up it all just went soggy and soft. Removed the retainer to find the bloody things cracked.
There must have already been a crack or weakness there before because i had barely even put the bolt under any tension at all more than finger tight before it went jammy.
What to do? Can i continue with only the two bolts and a knackered third or is a whole new box case in order?
Edited by carts60 on 16th Jul, 2011.
I have replaced a casing for just that, but then, I am anal *happy*
Those bolts shoud only be done up to about 18lbft which is naff all, and easily less than hand tight if your a bit of a brute*wink*
question is, if your engine is going to be anything other than a standard motor, would you risk it? I certainly never, and I have known others not to either, but then it 'might' be ok, but if the gearbox failed knowing that this damage was present, how would you feel then?
I think its going to be a personal choice, but my advice would be either replace the case, or at least have it welded, drilled and tapped, which might end up being more expensive depending on who you know.
carts60
Member #: 9335
Bromley, SE London
What could be the possible repercussions of trying the box with the current problem? Either with a bodge job on the thread on using only 2 bolts instead of the 3?
I'm not trying to skimp around the problem, but i'd like to at least know what my options are.
And im anything but a brute lol
Anybody have a spare gearbox case kicking about?? :)
If there were two threads left diagonally opposite i might chance it, but not like that.
I'd rip the broken bit off and see if there is enough meat to get a helicoil in, if not I'd find another case.
carts60
Member #: 9335
Bromley, SE London
Righto!
Just to confirm helicoiling is where you drill out the old thread, re-tap a larger thread then put in an insert which contains the original thread??
Cheers chaps
yep thats right.
carts60
Member #: 9335
Bromley, SE London
Can someone please confirm its an M7 thread? I'v been to the garage to check and i'm fairly sure it is, but i dont have a tap to quickly run into the hole to make sure...
Its 5/16 UNC
carts60
Member #: 9335
Bromley, SE London
Well im glad i asked that question! lol Literally had my finger on the buy button
edit*****
Sorry posted in the wrong topic *happy*
Edited by Sprocket on 16th Jul, 2011.
You might find that a timesert would be best in this case (punn not intended) as they are solid instead of being a coil.
Something like this...
http://cgi.ebay.co.uk/Classic-MINI-Wurth-T...D-/130341080629
carts60
Member #: 9335
Bromley, SE London
Only problem is i'v got to go all to Warwickshire to get it fitted, by which time petrol will have cost more than a new case.
I'v ordered a helicoil kit so i'll give that a go first
1 - damage may have been instigated by the way you took the bearing out (read the early post on this subject)
2 - that photo looks very much like a helicoil has already been fitted - shadow round the left hand side, and especially because the thread is broken in a completely different place to the place the casting is broken on the right hand - so someone may have already fitted the wrong metric one (and fitted it very badly).
I thought this on one of my cases, the threads looked very similar to the pic above, and it initially looked like a helicoil had been fitted, but it was just the slight counter bore, and the fact the thread had been stripped.
I don't think a helicoil has been fitted, but all I can see is a 2D picture, so could well be wrong *happy*
miniminor63
Member #: 672
The oversills police
Oslo, Norway
It seems to me that you used these bolts to press the bearing in? Not the way to do it. I suggest you investigate how to work properly on gearboxes before you continue.
haimesyboi
Member #: 5702
Cornwall
Looks to me that it needs welding and a time sert putting in after the repair, i only use helicoils when the thread is stripped, not destroyed.
carts60
Member #: 9335
Bromley, SE London
The bearing was put into place using a drift and rubber hammer, not by attempting to use the retainer to push it in. I have fully investigated how to work 'properly' on gearboxes thanks although this is my first time undertaking such a process so i'd appreciate helpful comments rather than snide remarks
I'm not sure the damage was done I removed the bearing either Rod. I used a small drift on the outer race for about half its removal and then a larger implement once i could shift the mainshaft out the way a bit. Thats where i lost all my bearings and springs. I only used the larger tool on the inner race once it got stuck however although it slipped a few times and i ended up breaking the ball bearing part in the process.
At no point in time did i hit the casing.
I'll update on whether i'm able to put in a helicoil or not when the kit arrives during the week.
I think paying for someone to weld a repair is going to be cost ineffective, so if that doesn't work i'll look into getting another case.
Anybody have one spare at all in case??
Edited by carts60 on 17th Jul, 2011.
PaulH
Member #: 2340
Dublin Ireland
I have seen this a good few times normally caused by crud at the bottom of the thread hole, when you tighten up the bolt presure is caused and it has to go somewhere( exit stage left) I would simply drill all the way through the main web tread a bit deeper and use a longer bolt this is simply a bearing retainer and only serves to stop the outer race from turning. If you put the other 2 bolts in at the right torque and you can get a bolt to pull 11nm in that hole with a bit of locktite then I would not worry for one minuite
On 17th Feb, 2009 Rob H said:
carts60
Member #: 9335
Bromley, SE London
Having just looked in the hole - or what is left of the hole i'v excavated a significant clump of congealed/compressed filth.
I was having a think about what to do last night, and came to the same conclusion of drilling deeper with a longer bolt.
I'll give that a go tomorrow
Thanks a lot Paul!
I'd have it welded before any helicoiling was done...
