Home > Help Needed / General Tech Chat > Idler shims to big
turbominij
Member #: 2104
Essex - UK
i have a problem i have just assembiled my transfer case to box to get the shim thickness right for the idler gear i have put two 1.031" shims in with the gaskit in and when torqued up to 18lb the idler gear locks up i have taken one out and measured the gap and get .028 so .025"+0.03" clearence my problem is 31+25=56/2=28 so i need 2x 0.028"shims to keep it in the middle. they dont do 0.028" shims
am i missing something ?
have i done something wrong?
Edited by turbominij on 16th Jul, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
Use a thicker gasket. The genuine gaskets are the best
have them surface ground down to size
yeah, the pattern gaskets are all over the plece.
turbominij
Member #: 2104
Essex - UK
the gaskit i am using is a minispares one in their set pale cream coloured one
Minispares stock good stuff and some crap stuff. Buy a genuine ROVER gasket.
turbominij
Member #: 2104
Essex - UK
well it ended up being user error(it does help if you put the bearing in far enough!!!) FAIL!!!
but not to far so you close off the oil way.
as for the shims i now need two 38s does anyone have any?
