| Home > General Chat > How hot is to hot? | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
18th Jul, 2011 at 02:24:06pm
I'm taking the mini to Snetterton this weekend for a 20min taster session round the track. I am slightly concerned about engine temps.
18th Jul, 2011 at 02:57:46pm
just to add i have a 74 degree undrilled stat |
18th Jul, 2011 at 03:05:50pm
I think that would depend on wether you are running NA or FI, I run the Race motors at 100 deg C and try to keep them on the good side of that, If the cars are doing a lot of following in an attempt to pass, they can run as high as 110 115, things will start to fail above that in my experience. are you running plain water or coolant if your only running water change it for coolant and that should get you into the 90's On 17th Feb, 2009 Rob H said:
18th Jul, 2011 at 03:18:19pm
I'm running halfords pre-mix coolant. but as it happens the car was running cooler than it was after i topped it up with some old coolant that was laying around as my fresh stuff was empty. |
18th Jul, 2011 at 05:07:22pm
what rad have you got on there ........standard ?
18th Jul, 2011 at 05:18:08pm
no, i've got this 2 core rad from minispeed
18th Jul, 2011 at 05:24:04pm
if you are sure that you are ok in the coolling department....... the problem will lie in retarded timing around 10deg or so you need a good set up
18th Jul, 2011 at 07:03:33pm
i just cleaned out all the fins in my rad and re-positions the fan into the cowel better. and its gone down by about 8 degrees. |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
18th Jul, 2011 at 07:58:30pm
Yeah as above. Maybe change the fan for a 6 blade type?? |
18th Jul, 2011 at 08:58:31pm
i've got a plastic fan at the moment, are we saying the 6 blade is better?
Edited by Simon on 18th Jul, 2011. |
18th Jul, 2011 at 10:49:28pm
I've been using a Minispares 4 core on my racecar for several races. Never a problem with a mechanical fan.
18th Jul, 2011 at 10:56:55pm
Another thought it's it's gone a little lean, as i notice when mines lean it gets hotter. Best 1/4 mile 13.2 seconds @116 mph
19th Jul, 2011 at 12:06:23pm
yes mat, too lean and ignition retarded to suite that engine, may be
19th Jul, 2011 at 01:51:05pm
the car is fresh off the rolling road at T&M, the fueling is spot on. There is room for further timing advance, Ray said even another 5 degrees over the whole map, but suggested putting a few more miles on the engin (only 800 miles so far) before advancing any further. |
19th Jul, 2011 at 02:01:32pm
show us your map If something is worth doing, it's worth doing half of. |
19th Jul, 2011 at 05:30:51pm
Sorry if this is this doesnt come out right gents but i think simon is just wanting to no if he is ok at snet so long as his temps dont go above 110/115
19th Jul, 2011 at 08:20:38pm
exactly, the track day is in 4 days, in that time i'm not going to be changing fans or radiators or my map or fueling as its only just been setup.
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
19th Jul, 2011 at 08:26:21pm
Could just be the sender.
20th Jul, 2011 at 08:14:37am
I would say firstly callibrate the gauge and sensor.
20th Jul, 2011 at 10:43:39am
I've had the stat out this morning and tested that and thats all working fine.
Edited by Simon on 20th Jul, 2011. |
21st Jul, 2011 at 08:33:56pm
well they say actions speak louder than words.
Edited by Simon on 21st Jul, 2011. |
