Home > Help Needed / General Tech Chat > ecu or not to ecu
chesh
Member #: 9470
car came with no ecu. so the vale just float about under bonnet. is car better off with out it.
the anti run on vale fot the carb ( think that wat its called) is tho there and there is just a bolt in the end of the hose. are these parts need as some places say yes and some say no.
No, just block it off.
Someone may tell you different though.
rick
chesh
Member #: 9470
is that both off them.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
