| Home > Wanted > Gt17 v clamp And pipe for air filter | |||||||
19th Jul, 2011 at 08:12:08am
As above, ta
19th Jul, 2011 at 08:40:44am
Try Ebay, searching for Saab parts -its how I found mine. |
19th Jul, 2011 at 08:58:13am
What sort of pipe you after mike? I've got a bit of flexi hose? Aint the nicest of pipe like, like a clear with yellow tinge colour Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
19th Jul, 2011 at 11:03:46am
Its the steel inlet tube with the flared end. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
19th Jul, 2011 at 12:02:29pm
The one I had was an aluminium casting, which I cut down to suit. |
20th Jul, 2011 at 12:32:49am
As above, its an ally casting and has a stepped end with an Oring, its not flared
20th Jul, 2011 at 07:06:48am
Mike, what dia is the inlet to the compressor housing, can we not weld a short piece of ally tube on so that you can just use a filter/silicone pipe with good old jubillee clips??
