| Home > Help Needed / General Tech Chat > denso alternator whining like a biatch.. | |||||||
20th Jul, 2011 at 08:53:02pm
Hi, i have an annoying issue with my nippon alternator that has only just started to occur.
20th Jul, 2011 at 09:07:11pm
Is it a V belt ? If so and it has worn enough to touch the bottom of the vee then its likely to slip under load. v belts are meant to drive on the flanks of the vee |
20th Jul, 2011 at 09:09:23pm
sorry, should have said, its a grooved belt and that's new too. |
20th Jul, 2011 at 10:19:02pm
battery nearly dead, making the alt harder to turn?
Yes i moved to the darkside |
20th Jul, 2011 at 10:24:54pm
Will charge the battery, it's slightly low.. Did really tighten the belt, with no luck :( |
20th Jul, 2011 at 10:30:53pm
Water? On 26th Oct, 2004 TurboDave16v said:
20th Jul, 2011 at 10:37:15pm
On 20th Jul, 2011 Sprocket said:
Water? In it or on the belt? I wouldnt think so.. No recent leaks Edited by MarkGTT on 20th Jul, 2011. |
