| Home > Help Needed / General Tech Chat > A slightly off topic diff question for you all to think about. | |||||||
20th Jul, 2011 at 09:24:12pm
Right, the scenario is this, you have a front engine, rear wheel drive car and you have the OPEN diff out of it on the floor.
20th Jul, 2011 at 09:57:48pm
On 20th Jul, 2011 James_H said:
Now put resistance onto the 'input' shaft as if that was driving a road wheel. Does the 'input' shaft still spin or do you simply spin the other 'output' shaft? This line is a little confusing. Can you explain a little more On 26th Oct, 2004 TurboDave16v said:
20th Jul, 2011 at 10:20:29pm
No worries Sprox, did think it would happen with at least one part of it all TBH!
20th Jul, 2011 at 10:24:30pm
The oposite oputput shaft would then rotate in the oposite direction On 26th Oct, 2004 TurboDave16v said:
20th Jul, 2011 at 10:24:41pm
If you spin one output shaft it will usually favor spinning the other output shaft as there is a gear ratio between the outputs and the inputs...
20th Jul, 2011 at 10:48:13pm
Goooood!
20th Jul, 2011 at 10:49:10pm
yes,
20th Jul, 2011 at 11:16:46pm
Perfect.
21st Jul, 2011 at 12:28:31am
with the input shaft turning, theoretically both output shafts will turn at an equal speed. Slow down or stop one of the output shafts and the other will increase in speed proportional to how much the other has slowed down by, the input shaft is still turning at the speed it was before. On 26th Oct, 2004 TurboDave16v said:
21st Jul, 2011 at 12:31:05am
also, if you flip the diff or the axle over, you will reverse the direction of the road wheels, so make sure you put the diff back in the right way up On 26th Oct, 2004 TurboDave16v said:
