| Home > Help Needed / General Tech Chat > doh MPI block | ||||||
195 Posts Member #: 26 Advanced Member Cannock |
4th Apr, 2005 at 12:30:10pm
Just grenaded my mpi cooper engine however the block is actually still in reasonable condition (i.e. it will be fine with a +20 rebore). I dont really want to put a 1293 mpi engine back in my cooper (I will just get a new one from somewhere). |
4th Apr, 2005 at 12:36:06pm
The emissions test follows the engine not the car...
AlexF |
4th Apr, 2005 at 12:43:38pm
so If i put a mpi engine in a 1973 car then i have to have a cat and get it though what a 1998 car has to comply with then I have no hope. Bugger. So ive now got a 1275 paper weight. :( |
4th Apr, 2005 at 12:57:35pm
You'd expect so...
AlexF |
4th Apr, 2005 at 12:59:59pm
do you want to sell your mpi inlet manifold, turbodave is looking for one On 15th May, 2009 TurboDave said:
4th Apr, 2005 at 01:01:04pm
Jim i still want to keep my cooper i will just be looking for another mpi engine to drop into it. |
4th Apr, 2005 at 02:24:13pm
If you find one, sell us a manifold to help re-coup the cost!!! On 17th Nov, 2014 Tom Fenton said:
4th Apr, 2005 at 04:08:49pm
If you decide to turbo the MPi block the main issue will be lack of distributor hole and drive, so you will have to run mapped ignition. As a plus point though, you will have the mountings for the smaller higher mounted alternator, so will be able to use the MPi front mounted radiator.
5th Apr, 2005 at 12:18:33am
thought the MOT was based ont eh car OR engine, whichever is older... turbo 16v k-series 11.9@118.9 :)
5th Apr, 2005 at 08:12:59am
On 04/04/2005 16:08:49 Tom Fenton said:
As a plus point though, you will have the mountings for the smaller higher mounted alternator, so will be able to use the MPi front mounted radiator. Aren't these monts on the head, and not the block??? If so, you'd have to get a Mpi head to modify as well. On 13th Jul, 2012 Ben H said:
5th Apr, 2005 at 08:24:07am
hmm yeah i think they are vegard I will have to have a look when i get home tonight.
5th Apr, 2005 at 10:19:51am
I thought there were different mountings on the block as well?? But could be wrong is 4 years since I touched an MPi.......
5th Apr, 2005 at 10:21:52am
The block might be different as well, But the main alternator mounts are on the head :)
5th Apr, 2005 at 10:31:26am
BOOOM BOOOM!!
244 Posts Member #: 34 Senior Member |
5th Apr, 2005 at 07:56:00pm
evolution is correct the emissions go on which ever is the older, but you will probably have to prove that the engine is older, and also show the MOT tester where in the rule book it says you can! (copy on line somewhere!!!)
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
9th Apr, 2005 at 05:19:16pm
mpi block on ebay
