| Home > Help Needed / General Tech Chat > fueling problems | |||||||
286 Posts Member #: 4008 Senior Member near cardiff np12 |
23rd Jul, 2011 at 08:03:21am
hi, my mini has been sat doing nothing for a while so decided to go get here yesterday but it wont start, normal mini thing i guess,
23rd Jul, 2011 at 10:27:35am
the float bowl valve is goosed or sticking, you need to strip the carb and sort things, new valve or the sticking out, i would remove the plugs and turn the engine over with the fuel supply disconected and wiss the engine over to remove the petrol after that i would change the oil
23rd Jul, 2011 at 12:29:24pm
stick a bit of oil down the bores too, gthe fuel will have washed all the lubrication away. On 28th Aug, 2011 Kean said:
23rd Jul, 2011 at 07:41:56pm
ive had it running today but its over fueling with the pump running.
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
24th Jul, 2011 at 03:44:58am
id agree with these guys, its gona be the float valve, when you turn the pump on its blasting fuel past the valve and flooding the engine, when the pumps off the engine runs off the fuel in the float chamber.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
24th Jul, 2011 at 08:16:26am
job done ill take a look today thanks |
24th Jul, 2011 at 10:13:38am
If it's a brown turbo clubman. You should just give it to me. I'll look after it. :) If something is worth doing, it's worth doing half of. |
24th Jul, 2011 at 05:04:43pm
the way its going mate it will be on fire soon!!!
Edited by flyingturd on 24th Jul, 2011. |
24th Jul, 2011 at 05:23:40pm
it will be the tiny little spring loaded needle valve that the float pushes on that needs looking at, there may be a bit of dirt or wear stoping it closing/ sealing.
Edited by MONSTER HEDGEHOG on 24th Jul, 2011.
