| Home > General Chat > OT grinding concrete | |||||||
23rd Jul, 2011 at 08:49:05pm
My concrete floor for the conservatory has been done wrong again, its 5-10mm too high.
I seriously doubt it! |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
23rd Jul, 2011 at 08:52:46pm
Yep you can hire concrete grinders/scrabblers from most good hire shops-tend to be the larger outfits that do small plant and the like, the grinders i have used are like a floor polisher with abrasive blocks underneath fine finish but slow, never used a scrabbler type machine but these i think are quicker but rougher.
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
23rd Jul, 2011 at 08:54:54pm
Sounds like a scrabbler might be just the ticket, doesnt matter if its rough as underfloor heating is going ontop of it I seriously doubt it! |
23rd Jul, 2011 at 08:57:31pm
you'll get scabblers and grinders from any of the good hire shops paul |
23rd Jul, 2011 at 08:57:47pm
Sound like youve had some bother there mate! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
23rd Jul, 2011 at 09:01:52pm
On 23rd Jul, 2011 MikeRace said:
Sound like youve had some bother there mate! I wish it was as minor as 'bother' I seriously doubt it! |
23rd Jul, 2011 at 09:02:06pm
Only ever used them for suface prep so not sure about skimming off 10mm or so, speak the hire people and they should be able to reccomend something, we use A plant for stuff like that, but again loads of hire places, a diamond cup wheel for an angle grinder is good for egdes and corners-best of luck with it, sounds like they forgot to allow for u/f and floor covering? On 18th Oct, 2013 apbellamy said:
23rd Jul, 2011 at 09:03:40pm
Oli, its either grind it all down or dig it all out............again I seriously doubt it! |
23rd Jul, 2011 at 09:05:29pm
Yep I see that-sorry to hear about all the bother-fucking muppets! best of luck with it
On 23rd Jul, 2011 paul wiginton said:
Oli, its either grind it all down or dig it all out............again On 18th Oct, 2013 apbellamy said:
23rd Jul, 2011 at 10:04:11pm
10 mm isn't an issue usually to grind down |
23rd Jul, 2011 at 10:39:38pm
On 23rd Jul, 2011 Rob Gavin said:
10 mm isn't an issue usually to grind down Just messy as fuck On 26th Oct, 2004 TurboDave16v said:
23rd Jul, 2011 at 10:41:40pm
not too bad if you can get water suppresion |
23rd Jul, 2011 at 11:56:17pm
On 23rd Jul, 2011 Rob Gavin said: `
not too bad if you can get water suppresion Thats what I was meaning though. All that concrete ends up as a fluid you are working in and around. Its similar to working with wet concrete without its ability to set and go hard. I have helped a friend grind a large floor area in a skatepark, but it was ony to smooth the surface off, not 10mm or so. It took several hours. It's doable, but I don't envey you. Is there no way to accomodate the 10mm? I assume that is the extra 'hight' required for the UFH that the builders never accounted for when the concrete was layed? Bastards! On 26th Oct, 2004 TurboDave16v said:
24th Jul, 2011 at 09:08:53am
Fortunately it wont be me sorting it.
24th Jul, 2011 at 10:10:43am
Is this the same lot you had hassle with before? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
24th Jul, 2011 at 10:49:50am
Paul, youre best off taking the surface up with a small concrete breaker by chipping across it, never done any good with anything else, its just ballache, then fill any deep holes with a small amount of concrete and once youre happy with the level, build it back up to something like with self levelling compound. If they did the concrete to the correct height, if anything it should be a few mm low, concrete shrinks as it sets and dries. Hope thats of use to you chap. Any deep areas you need to self level, mix the levelling compound with a small bag of plastering sand to bulk it out. Edited by Carlzilla on 24th Jul, 2011. On 26th Jan, 2012 Tom Fenton said:
24th Jul, 2011 at 10:59:13am
24th Jul, 2011 at 12:10:05pm
On 24th Jul, 2011 MikeRace said:
Is this the same lot you had hassle with before? No mate, they gave my money back and let me keep the £13,000 conservatory. This is another company who are an established building company who gave all the promises to put it right within 2 weeks, which I thought was a tall order - I expected 3 weeks, but its been 5 weeks now and all theyve done is dig out the old foundation, dug and poured a 1m deep x 600mm wide foundation for us and built the walls. I seriously doubt it! |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
24th Jul, 2011 at 12:20:40pm
Paul if its a reputable firm and its their fuckup get them to remedy it or take legal action
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
24th Jul, 2011 at 12:30:06pm
I am expecting them to sort it, Im just looking at what options there are other than smashing it out and risking damage to the foundation and brick walls I seriously doubt it! |
24th Jul, 2011 at 02:54:57pm
Could always run one of those disk cutters with the ability to set the depth all over the floor, then kango out the chunks. Is it being screeded or tiled straight on top of the concrete?
24th Jul, 2011 at 03:10:04pm
No, 130mm of underfloor heating I seriously doubt it! |
24th Jul, 2011 at 06:24:02pm
does the insulation sit on the conc then the ufh on top of the insulation then screed?
My build thread..
24th Jul, 2011 at 06:43:32pm
That would be the easy way but then Im paying to heat up the concrete slab instead of the room. Being detatched it costs enough to heat this place anyway without wasting it Edited by paul wiginton on 24th Jul, 2011. I seriously doubt it! |
