Home > Help Needed / General Tech Chat > separating the block from the gear box.. it wont budge!!
c2_mad
Member #: 4215
hi guys, trying to dismantle my engine today... got everything off, just need to separate the block fron the gear box. removed all the nuts, bolts etc... but the dam thing wont budge:( seems like someone used a but to much "gasket glue" any advice? really pissed at the moment. fml
cheers
Advice... Don't do it pissed.
Are you sure that all the fixings are removed? There's a couple of sneaky ones that are easily missed.
c2_mad
Member #: 4215
yeah mate... i have checked it a couple of times....really dont know what to do, as i dont want to pry it, as might ruin the mating...
Might sound silly but have you took off the flywheel and clutch housing?
jamie@thefatgarage
Member #: 9345
Sheffield
I suppose the best question at this point would be how many bolts and nuts have you taken off from the back (from the timing cover, past the diff and then to where the primary cover is) then how many across the front (timing cover to primary cover) then how many inside the primary cover (unless you've removed it)?
edit, drink on my part too...
Edited by jamie@thefatgarage on 25th Jul, 2011.
c2_mad
Member #: 4215
hi guys, finnally got it off... just needed a bigger crow bar in the end.
thanks for all the help and advice. engine is fully striped now.
crow bar on mounting face's..................... arrrrrrrrrrrrrrrrrggggggggggggggggggggggghhhhhhhhhhhhhhhhhhhh
Edited by wolfie on 25th Jul, 2011.
c2_mad
Member #: 4215
no mate... i wouldnt dream of doing that... levered it of the end of the crank... bill sollis style...
I was going to suggest turning the whole lot upside down and using a nylon mallet.
bennyy
Member #: 9037
Doncaster, yorkshire
Levering off the idler gear is easiest I find.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
c2_mad
Member #: 4215
i had tried the mallot... didnt even move....
