| Home > Help Needed / General Tech Chat > Wheel arch question | |||||||
28th Jul, 2011 at 10:04:54am
Although I would like to use them, the standard arches (ie, disk brake onwards but before sportspack) don't quite cover my 6X10 wheels enough to be "legal".
28th Jul, 2011 at 10:14:08am
How about these
28th Jul, 2011 at 10:25:53am
Thanks Andy, but yes, they are too wide.
28th Jul, 2011 at 10:28:02am
you could look at it another way; get a cheap set of 5" wheels to run it through the MOT |
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
28th Jul, 2011 at 11:01:37am
You will find that it is not an MOT failure to have your wheels extending past your arches. What you will find tho is the police will pull you over and fine you or give tou an unsafe vehicle slip. This is what happened to me. You then have to amend the problem and grt the slip signed by an MOT station even though it is nothing to do with them, pay them to do the check and then present the signed slip back to your local police station, where they will no doubt tell you the problem isnt fixed! As they did with mine. The turbo build has finally started |
28th Jul, 2011 at 11:07:08am
I thought it was visible tread outside of the body work/arch that was the problem?
28th Jul, 2011 at 11:08:26am
it is. Looking at your build thread, I would say you are OK with the standard arches, certainly on the rear. Edited by apbellamy on 28th Jul, 2011. On 11th Feb, 2015 robert said:
28th Jul, 2011 at 11:09:02am
either minispares or minisport made standard black plastic arches that were wider not sure if there still available Crystal Sound Audio said:
28th Jul, 2011 at 11:59:14am
http://www.minispares.com/Product.aspx?ty=...id=37722&title=
On 5th Sep, 2011 Vegard said:
28th Jul, 2011 at 12:00:55pm
On 28th Jul, 2011 wolfie said:
either minispares or minisport made standard black plastic arches that were wider not sure if there still available Monte Carlo? On 26th Oct, 2004 TurboDave16v said:
28th Jul, 2011 at 12:13:05pm
Police will put you if tread sticks out from the arch, the way to get around it is stretched tires, still as 'dangerous' but nothing the popo can do. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
337 Posts Member #: 9138 Senior Member wolves |
28th Jul, 2011 at 01:07:11pm
nothing to do with mot . Construction and use is a different matter . If i tested it i would prob just issue an advise sheet
28th Jul, 2011 at 02:36:42pm
Many thanks for all the replies....
28th Jul, 2011 at 03:16:51pm
This is more or less what I have on mine, but painted the same colour as the car. As they are fitted to the lip they can be trimmed to fit different offset wheels.
On 28th Jul, 2011 Scruffy said:
http://www.minispares.com/Product.aspx?ty=pb&pid=37722&title= These screw from underneath also it would seem http://www.twin-turbo.co.uk
28th Jul, 2011 at 04:26:21pm
Or do it an easy way for mot as your wheels imo are not wide enough to cause a problem just tape some flexible rubber inder the arch so it covers the tyre if your worried, i ran std special arches with 12x6 ultralights with my mini never had a problem with the fuzz Drives
28th Jul, 2011 at 05:23:52pm
or wizz 5mm off the wheel where it bolts to the hub . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jul, 2011 at 06:07:55pm
Thus far ive never been pulled for anything on my car (im actually amazed tbh)
28th Jul, 2011 at 06:37:45pm
I agree, it's Mr VOSA that you need to worry about, they have a good knack of finding something wrong with your car! On 26th Oct, 2004 TurboDave16v said:
28th Jul, 2011 at 07:33:14pm
Theyd love me then in which case. In all fairness i do try not to give the police reason not to pull me by driving reasonably sensibly, and they generally just seem interested as they drive past and whatnot.
