Home > General Chat > What makes a turbo su different?
Alex1340
Member #: 111
Loughborough
Hi guys. What makes a turbo su carb different from a standard and can a standard be converted?
You know when you regeat selling something, I'm having one of those moments.
wez
Member #: 9271
Stoke on Trent
There's quite alot of threads on here about this and some good diagrams too, id find a link for you but im on my phone at the mo, have a search.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
wez
Member #: 9271
Stoke on Trent
I think ive figured out how to do links from my phone now, so here goes http://www.turbominis.co.uk/forums/index.php?p=vt&tid=217478 there's a good diagram on here of whats what,
bennyy
Member #: 9037
Doncaster, yorkshire
Yes they can be converted, the turbo su are a sealed unit, there are slight differences on ther carb body too
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
all i did.. block up the overflow,
reverse the spindle seals ( althouhg mine has 2 sets in for some reason i just reversed the inner seal)
drilled for the float bowl pressure port (t - piece trick also cures this)
plumb up like a turbo carb
not forgetting the spring and needle
i sealed my dashpot to carb body with a neat bead of silicone sealant
