| Home > Help Needed / General Tech Chat > Carb pissing out fuel !!!! | |||||||
43 Posts Member #: 9469 Member letchworth herts |
29th Jul, 2011 at 09:42:44pm
Hi just put the old turbo bak together and now it see
29th Jul, 2011 at 10:11:05pm
There is no overflow on a turbo carb, how are the pipes connected?
29th Jul, 2011 at 10:17:53pm
it cant be connected that wrong as we got it started!
My build thread..
29th Jul, 2011 at 10:43:10pm
And there was fuel drippin at the bak into the heat shield !! Everything done up tight |
29th Jul, 2011 at 10:45:13pm
There a pipe from the fuel regulator into the carb and the return onto the plenum !! Then Peter Baldwin blocked another one off think that went to solenoid might b wrong tho |
![]() 825 Posts Member #: 2208 Post Whore Essex |
29th Jul, 2011 at 11:45:42pm
what ever you do dont put the pipes on the wrong way round and fill you intercooler with fuel!
30th Jul, 2011 at 10:46:17am
if you are Sure! yopu have the pipes conected right!
30th Jul, 2011 at 03:08:18pm
Yer they are correct double checked them they are all new rubber fuel pipe !! I thinking it the carb ain't been used for at least a 6 months !!! Maybe more and ain't got a clue about rebuilding them |
30th Jul, 2011 at 05:19:18pm
mike we'll take it to bits tomorrow mate.
My build thread..
30th Jul, 2011 at 05:34:45pm
Yer sounds good lol smoking, I was prepared for little smoke but that was like dot cotton on 60 a day !!!! |
30th Jul, 2011 at 05:43:58pm
blowing o's! lol My build thread..
30th Jul, 2011 at 06:00:27pm
Take the dashpot off and start the fuel pump, then you will know for sure. |
31st Jul, 2011 at 02:04:11pm
Here now took dashpot off no fuel comin out ! Hoses are tight and correct we are confused !!!! |
31st Jul, 2011 at 04:15:55pm
a sticking intermittent float bowl valve
31st Jul, 2011 at 04:41:19pm
think it must of cleared itself as it was fine once we started it up.
My build thread..
