Home > Technical Chat > Dogbox
Tareq
Member #: 970
Bahrain
Hi I'm looking at buying a dogbox gearset.
Looking at the options there is Swiftune and MED
Anybody tried the MED set? Cost is much lower.
Thanks
They are both very similar, i have the Swiftune set which is superb
I'd go for the swifty kit for a couple of reasons,
1 the selector forks are bronze,
2 the layshaft is multi peice so its a bit more rebuildable and there are more ratio's available
Joe means layger not shaft
oops,
yep dont wan a muti peice one of those!
Very nice piece of kit that swiftune kit. I have been lucky enough to have one in my hands, but not lucky enough to own it :(
Tareq
Member #: 970
Bahrain
Thank you for your comments. I was leaning towards the Swiftune kit as all their stuff seems to be topnotch. Wish they would drop the price!
Tareq
Member #: 970
Bahrain
Picking up the gearkit on Saturday from the couriers
Excellent, which did you go for in the end?
johnK
Member #: 690
Norfolk
Tareq, may be a bit late for you but the med kit is very nice to use, it's the gearset designed by Mick Barrett for the sequential project, it drives on the road like a normal gearkit, very impressed, certainly usable in road car, I've not given it any abuse yet, this is with one of Roberts clutch assy's on it. If anyone is considering a kit, it's more than worth a look.
Jk
If Carling made Mini engines
Tareq
Member #: 970
Bahrain
I ordered the Swiftune kit. Bit more expensive. Was thinking about the MED kit but after the last conversation I had with them... you know
I've been looking at the pics of that sequential kit. Looks quite simple. Its the rods to the forks that look abit messy. You and your CNC friends should be able to wip one up in a weekend!
mw3
Member #: 9590
Derby
Ive always wondered what a dogbox would be like for normal road use, bike engined kit cars seem to work ok because the gearbox runs at less than engine speed (1.6 x less for example) so down changes appear to go quite smoothly.
How does this work with a Mini Dog box? is there a lot of backlash in the dogs?
Matt W
On 14th Mar, 2012 mw3 said:
johnK
Member #: 690
Norfolk
Yes the backlash is quite large and loose, certainly more than the project I'm currently working on, but I was amazed how nice it is to use just pootling around the road, no notchiness or crunching, very positive engagement etc you really can't tell it's a dog box, wether this will change once the dogs have the corners smoothed off, time will tell.
Tareq, I understand but it is a good product so far, I bought mine 5years ago, one of the first made.lol. The swiftune has un rivalled reputation looking forward to seeing it under your k motor
Jk
The dogs shouldnt round off John
Tareq
Member #: 970
Bahrain
Eventually the dogs will loose the angle on the edges. Driver skill would determine how long that takes.
Would be nice if someone came up with a kit for a shift drum, ratchet and other bits needed to convert to sequential. Loads of space in the gearbox on the speedo drive area. Could nick a few bits of a FTR or similar gearbox for the ratchet mechanism.
I would have a go but its difficult having anything creative machined over here.
johnK
Member #: 690
Norfolk
Tareq, "driver skill" that's me knadgered then.lol! If I didn't have an awesome design project underway (not mini) I could be swayed to having a look, this time next year maybe.
oo John what are you working on?
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Already have , currently undergoing testing in a road car .1500 +miles with no issues. Even the "reverse" is working fine .Fingers crossed maybe in a position to start making kits in about 6 months job permitting
Tareq
Member #: 970
Bahrain
Fantastic. Keep us informed
johnK
Member #: 690
Norfolk
Excellent 5ports, looking forward to seeing it!
Gr4h4m, with a tail wind it'll be on our stand at Autosport in Jan!
