| Home > Help Needed / General Tech Chat > head gasket oil leak? | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
31st Jul, 2011 at 03:34:22pm
Just sprung a big oil leak which seems to be coming from the exhaust side near the water pump end of the gasket.Oil running down the block,front cover and spots on the pipework in that area.Is this a well known failure mode?I seem to remember the oil feed to the rockers passes up this area.Any comment would be much appreciated before i start pulling the head.BTW the oil press is 55psi on the relief valve. 'Where does the engine go?' |
31st Jul, 2011 at 04:14:03pm
steve yes thats where the gallery is a shade off set from the middle of the head about 2" in, have you tried to retorque the head up ? maybe this would cure it but i doubt!
31st Jul, 2011 at 06:30:57pm
If we are talking about the oil feed to the rockers then I thought it came up on the other side of the block i.e. the alternator side ? |
31st Jul, 2011 at 06:53:51pm
It does dave, inline with that square lug that sticks out of the back of the block. Edited by matty on 31st Jul, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Aug, 2011 at 06:40:45am
Thanks for the input.I suspect then I have a head gasket blow into the pushrod area.I've seen a report of this on an MG forum. 'Where does the engine go?' |
