Home > For Sale > CAM6232 A+ 1275 Crank
Has had a 0.010" grind on all journals, which now need a polish before use. Tail near perfect. Good base for modification. I'll drop it into Fast Carl FOC if you like.
£40 plus £8 postage. Can take to MITP.
Bump. Can take to MITP
leighsmith
Member #: 9560
Warning this post contains a potentially stupid question!
Will this crank fit an A-series engine?
I have been given a engine with a knackered crank for my birthday off the missus, she didn't know the crank was screwed and I changed my mind from just fitting it to stripping it first, so glad I did! It's had a 20thou re-bore, and the existing crank had a 10 thou re grind so if this is suitable then I'll have it please.
It will go in either A or A+ engines. PM me if you want it.
Bump. Offers?
i'll give you £20 for it if the tail is perfect
Edited by fastcarl on 1st Sep, 2011.
I'll chuck it in the car when I fetch those bits up to you. you can give it a once over
Word
respec fatha
