| Home > Help Needed / General Tech Chat > Rear Subframe mounting points | |||||||
559 Posts Member #: 2775 Post Whore Aberdeen |
31st Jul, 2011 at 07:37:29pm
I am away to replace the two rear corners where the rear subframe is mounted with the captive bolts.
31st Jul, 2011 at 07:40:46pm
Do one side at a time, then you can measure from the other side. You can be slightly out as the trunions are rubber mounted. On 11th Feb, 2015 robert said:
31st Jul, 2011 at 07:52:11pm
I got a good tip from Somerford minis.
31st Jul, 2011 at 07:56:19pm
That is kind of what I was thinking. I have the shell sitting upright on its front bulkhead so was going to make a template with some flat bar. I am worried about the car crabbing when it all goes back together. Edited by lockfast on 31st Jul, 2011. |
31st Jul, 2011 at 08:06:24pm
I can't remember the last time I saw a Mini 'crabbing'
