Home > Beginners Tech > Estate rear wide window removal
NickG
Member #: 7912
Australia oi oi oi!
Bit of a lame question.
But how the he'll do you remove them? Pulled the trim of not sure what to look at next inside the car?
Has any one done it? What channels strips did you replace it with?
I have found for the front sliding windows the felt 850 oness worked best? May e cut 2 up to fit?
Mine don't slide nice at all anymore..
Edited by NickG on 1st Aug, 2011.
Kean
Member #: 341
aka T2clubby
South Staffs
Hi Nick
You need to remove the external window frames from the sides of the car then Unbolt the trim clips from inside, which should enable you to remove the glass and seals. There maybe small screws holding the seals in place as well.
Hope this helps but its been a long time since i did mine.
You can actually do it without removing the surrounds. First slide the front window all the way back, remove the front upright section of seal. Now dig about in the channel and undo any screws. With this done locate the plastic slug that is screwed in to stop the rear window being able to slide forward, remove this. Slide both pieces of glass forward and dig out any screws and remove. With this done and a bit of force you should be able to slide the lower channel out. Once this is done it should give you enough room to manoeuver the glass out of the frame.
NickG
Member #: 7912
Australia oi oi oi!
Excellent thanks :)
