| Home > Help Needed / General Tech Chat > clutch slip | |||||||
101 Posts Member #: 9376 Advanced Member birmingham |
3rd Aug, 2011 at 06:41:13pm
hi have a problem on my moke 998 cooper about 70 hp at the fly wheel recently swaped the clutch as oil seal was leaking went to skeg mini fest and another whow about 500 miles clutch starting to slip in top stripped it down expecting oil seal again but it is ok flywheel and back plate have a small bit of blueing about 4cm round got a mechanic mate to look he reckon high spot on flywheel or back plate should i get it machined or new or any other ideas fly wheel and back plate are lightened ard balanced and new clutch kit was a s type ap from min its help needed as mitp coming up cheers for reading this far |
7th Aug, 2011 at 05:27:43pm
hi there, if i were you if your budget will stretch to it fin a minispares ultralight flywheel backplate and a new orange cover have all the rotating assembly ballance up .......... the jobs put to bed and the motor will be very smooth and spin up very quickley!
