| Home > Help Needed / General Tech Chat > SPI Loom connectors | |||||||
23 Posts Member #: 9069 Member Dumbarton |
3rd Aug, 2011 at 11:02:26pm
Hi, I am using an SPI loom for my turbo engine, just trying to hook up the oil pressure switch, the switch I have has one spade and the engine as the earth, The SPI loom has to spade connectors to a diffrent type pressure guage i dont have. Any ideas how to make it work? |
3rd Aug, 2011 at 11:09:19pm
The SPi loom never had a pressure gauge.
8th Aug, 2011 at 09:40:52pm
Sorry I am a nugget, I mean the coolant sensor, the spi sensor is in the manifold and is twin bladed back to the ecu but I need to wire up the single bladed that is in the block below the thermostat housing. |
8th Aug, 2011 at 09:45:20pm
In that case just run a wire to the 13 way connector on the bulkhead, and connect it to the green/ blue wire, job done On 26th Oct, 2004 TurboDave16v said:
8th Aug, 2011 at 09:56:09pm
Cheers mate, it makes sense when you say it, I have been dealing with so many wires I dont know if I am coming or going. If I was to do this again I woulnt use the spi loom, I only did so because it had the fuel pump wiring. Its been a pain. |
