| Home > General Chat > head gasket fail | |||||||
4th Aug, 2011 at 08:51:39pm
well my head gasket went when jon betts was suppose to be coming tomoz (bad times)
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
4th Aug, 2011 at 09:01:33pm
Stick to the 450
4th Aug, 2011 at 09:07:40pm
cheers will get 1 tomoz £20 for a genuine payen turbo head set (bargain) 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
4th Aug, 2011 at 10:13:27pm
make sure you are using a corrctley calibrated wrench. and tourqe the gasket to 55 ft pounds final load.
4th Aug, 2011 at 10:48:25pm
Spot on about the calibration steve :)
4th Aug, 2011 at 10:55:50pm
I agree with Matt,
5th Aug, 2011 at 06:59:38am
whats the torque for arp's on oil joe ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Aug, 2011 at 07:06:26am
We have minispares 11 stud kit on the van and using arp lube we have these torqued to 45ft/lb's If something is worth doing, it's worth doing half of. |
5th Aug, 2011 at 08:58:37am
that could be my issue, i seem to think i torqued it to 65. Thanks all 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
5th Aug, 2011 at 09:06:47am
I have always gone to 30ft lbs lbs then to 55ft lbs. With a bk450 and had no problems at 18psi Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
5th Aug, 2011 at 09:27:04am
Robert, you can use the std arp torque setting but you need to bring them up to torque and release them several times (like 6-10).
5th Aug, 2011 at 02:19:20pm
On 5th Aug, 2011 Joe C said:
Robert, you can use the std arp torque setting but you need to bring them up to torque and release them several times (like 6-10). lol , yes joe ,but what IS the arp setting for oiled nuts ? did you actually read the queston ?
5th Aug, 2011 at 04:24:24pm
moved to tech section as i have questions 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
6th Aug, 2011 at 11:28:28am
Well good job you have found the reason Eden, that's always a good thing :) Best 1/4 mile 13.2 seconds @116 mph
6th Aug, 2011 at 12:07:11pm
yes matt defiantly learn from mistakes!
6th Aug, 2011 at 12:22:07pm
LOL.
6th Aug, 2011 at 11:46:33pm
ok, so ive put it all back together and it looks like i have the same problem.
7th Aug, 2011 at 03:31:50pm
Are the block and head surfaces known to be nice and true?
Edited by T3Tone on 7th Aug, 2011. -MINI CLUBMAN 1380 TURBO- |
7th Aug, 2011 at 04:12:54pm
I,m nowhere near as well informed/experienced/educated as some of the contributors on here but I use standard studs ,oiled, and at least 65lbs ft on all 11 studs.
7th Aug, 2011 at 04:20:42pm
I use uprated and standard studs, depending on which engine I'm on about. In all cases I use 68Nm.
7th Aug, 2011 at 05:46:02pm
I use the minispares uprated head bolt kit that comes with chamfered thick washers, I do them up in two stages with engine oil I go to 25 then 45lbs. this was following a minispares article that said they run them at 45...
7th Aug, 2011 at 07:19:39pm
well its never got close to overheating since the build. had head and skimmed block. so im 99.9% sure there true.
