Home > Help Needed / General Tech Chat > intercooler size??
scott the joiner
Member #: 9229
newcastle upon tyne
What's the best size for an intercooler I have one all plumed in etc but its not as big as every one seems to use its off a suzuki cappicino thing but fits good behind the grill on the metro where the oil cooler normally goes is any intercooler beter than none or does it not work like that? Thanks scott
wng691s clubby
Member #: 9252
Cleethorpes
any intercooler is better than none but larger the better i believe is the way it works
Done now needs redoing lol
scott the joiner
Member #: 9229
newcastle upon tyne
That's what I thought outs better than nout. Boost will be max 15psi probably only about 12 really but can always upgrade later I thought a good position in good air flow is better that a big intercooler with no air flow
almichie
Member #: 2065
Big intercoolers can give a larger pressure drop too though, so it's better to size fairly accurately.
Shaft seems nice and snug
bigger what way though, long thin inter coolers (like mine) will drop more pressure than short wide ones,
i have said it many times ..........an intercooler is NOT the icing on the cake ................ ITS MORE CAKE !!!
usuall the 2wd cossie cooler is fine for 220 bhp ish but the 4 wd one is more efficient .......... if your train of thought is down those lines, you cant go wrong!
paint spray the cooler matt black it gives its heat up a lot more!
scott the joiner
Member #: 9229
newcastle upon tyne
Its actually already black as std on the same lines as a mr2 cooler is putting a intake temp gauge a hard job? What sender do you use & what do you use to display the reading? Like Gauge wise?
Mini or metro? We have one from a defender td5 in the van. we have a temp censored screen from a pc case
MMMMMmmmmmm...... Caaaaaakkeee.
I have a cossie 4wd i plan to fit one day that i bought off kean. Im led to believe bigger is better on the subject. So long as you have a boost gauge and an inlet temp gauge i cant see there being a problem.
mr brightside
Member #: 9376
birmingham
just got a cossie intercooler of ebay paid a fiver for it 4wd its like kin massive where do i mount it
scott the joiner
Member #: 9229
newcastle upon tyne
Its for a metro I really need to sort the intake temp gauge out really so I can see what's happening any useful tips on that.
metroturbo
Member #: 989
North Yorkshire
http://www.watercoolinguk.co.uk/cat/Displa...itoring_45.html
Make sure you buy the 12V to 5V cable to go with these gauges.
scott the joiner
Member #: 9229
newcastle upon tyne
Thanks for the link when I seen the pic on the site I remember getting something like it with a job lot of stuff had a hunt found it hurry just what I needed next question do you just have the sensor end sort of hanging in the inlet pipe where it joins the plenum & have the wires just coming out from the silicon hose join if you catch me drift thanks for the help *smiley*
Yeah just put the end under a jubilee poking into the hose near the plenum, youll probably have to extend the probes wiring though as its really short
That's how we have it
scott the joiner
Member #: 9229
newcastle upon tyne
champion & the wires are already extended as its from a mini turbo that was broke for bits thanks for all the help again guys
