Home > Wanted > Throttle cable mount turbo
jlay
Member #: 1742
essex
Hiya i am after the plate that goes inbetween the manifold and the carb that the cables mount to and also the heat shield mounts to the bottom of. Please pm me if you have one
Thanks
James
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
jlay
Member #: 1742
essex
ah forgot to say my carb is the later one with the progresive throttle mount not the early one which i believe is different
jlay
Member #: 1742
essex
bump still after one if not i will make one from stainless
