| Home > Help Needed / General Tech Chat > Serious Megajolt Wiring Issues | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
7th Aug, 2011 at 06:54:39pm
Hi
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
7th Aug, 2011 at 07:21:56pm
i only run a 5amp fuse and its never blown so id swap that in the future.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
133 Posts Member #: 9277 Advanced Member Nottingham |
7th Aug, 2011 at 07:58:01pm
must of got some pins/wires mixed up on the connector :( Edited by danrock101 on 7th Aug, 2011. |
7th Aug, 2011 at 08:36:18pm
I had the molex connector made to order with the correct length wires etc, double checked it all again and cant fault it. The only thing I can think is stupidly when testing other electrical things, a 30A fuse ended up in the megajolt slot. This was in when it melted. Then swapping back to 10A the unit still powers up and starts to glow, but the fuse is still ok? Could it be my stupidity with the wrong fuse that caused it to melt?
8th Aug, 2011 at 04:53:45am
The wrong fuse wont cause it to melt, it just wont protect your megajolt from stupidity |
8th Aug, 2011 at 07:11:35am
A photo of what exactly has happened would help.
8th Aug, 2011 at 09:30:56am
Fuses really protect the supply, not the faulty item.
8th Aug, 2011 at 09:09:28pm
the only thing it can be if you know and can prove your wiring was fine is a faulty mj.
9th Aug, 2011 at 12:54:11am
Thank you all for the replies.
9th Aug, 2011 at 01:06:47am
Also forgot to mention, i will be considering buying a new MJ unit in the next few days, especially if mine is beyond repair. So if anyone has one kicking around, please drop me a PM. Thanks. On 25th Sep, 2009 mini13 said:
432 Posts Member #: 7856 Senior Member Essex |
9th Aug, 2011 at 09:55:20am
On 9th Aug, 2011 1293 sprite said:
I bought it used but new if that makes sence. The guy who had it bought it new, but never got it all installed. Is it possible he built it himself, and did a poor job of it? Or was it a pre-built one? |
9th Aug, 2011 at 06:26:19pm
Spot on Amp, I've had an email back from Martin. I'll copy and paste exactly what was wrong when I get on the laptop, but to cut a long story short it was built wrong, and I'm told it would never have worked properly since it was built! On 25th Sep, 2009 mini13 said:
9th Aug, 2011 at 11:20:34pm
Right, here is an explination from Martin of exactly what was wrong with the MJLJ:
