| Home > Help Needed / General Tech Chat > turbo re-build needed? | |||||||
![]() 34 Posts Member #: 9453 Member warwickshire |
8th Aug, 2011 at 09:56:03am
Dropped my car down to a local mini mechanic last week, as it was cutting out as you slowed down, various things tried, but he rang me and said it was dead slow, which I know it's not the fastest turbo mini out there, (did a 16.2 at avon) so I'm thinking it is going to be pretty f**ing rapid when it's sorted, anyway wanted it back for the weekend, so picked it up Friday, then I realised what he meant, on tickover it sounds and feels lumpy, when I drove away it had no power, and when the turbo is kicking in, clouds of smoke out the back, just wanted to check with you guys before we pull the turbo off, that this is the problem, oil seals? or any ideas. It's a standard metro engine I bought earlier this year, I have fitted an intercooler, dump valve, fuel regulator, electric pump etc to make it work. |
8 Posts Member #: 9554 Junior Member Wallasey, Wirral, Merseyside |
8th Aug, 2011 at 11:02:20am
Turbo seals can cause masses of smoke, usually a very pretty blue/white combination, does it clear? Or is it constant smoke?
Edited by autosportnorth on 8th Aug, 2011. -
8th Aug, 2011 at 11:24:13am
Engine seems ok, compression test was fine, there is a bit of wear but I was hoping to leave a re-build till the end of the year, the smoke is as you described, it used to appear when you changed gear, and accelerated, then stop, it has got worse, on Friday it was throwing out loads of smoke when the turbo kicked in and the smoke seemed constant |
8th Aug, 2011 at 11:31:10am
Hmm ok, hopefully you'll be lucky and its just a turbo :) But if thats exactly how its smoking, then yes, I'd be taking the turbo off, is probably worn the oil seals out :) -
8th Aug, 2011 at 11:54:34am
Cheers for your help, where would you reccommend getting the parts from. |
8th Aug, 2011 at 11:56:55am
I wouldn't recommend doing it yourself, a turbocharger is a precision piece of engineering that needs to be balanced and setup correctly on specialist hardware.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
8th Aug, 2011 at 12:21:12pm
There's plenty of members on here who've rebuilt there turbo's at home, depending on what turbo your running im sure you'll find a rebuild kit for less than 100.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
8th Aug, 2011 at 12:28:05pm
Oh it is doable, but I wouldn't recommend it, thats my angle. A component that spins at potentially 80,000 RPM can do a lot of damage if it isn't correctly balanced. -
8th Aug, 2011 at 01:01:33pm
You are only replacing bearings and seals. if you mark everything carefully and reassembled it keeping everything as you marked it, then the balancing won't be effected. On 11th Feb, 2015 robert said:
8th Aug, 2011 at 01:08:24pm
Obviously it's going to cost whichever way I go, is it worth going all out and fitting a better turbo, currently it's a standard T3 any thoughts |
8th Aug, 2011 at 01:13:08pm
There are lots of alternative turbo out there, but better is always subjective On 11th Feb, 2015 robert said:
8th Aug, 2011 at 04:07:16pm
Is this the correct turbo from a seller on ebay http://www.ebay.co.uk/itm/T3-T4-Turbocharg...=item588f3f308f |
8th Aug, 2011 at 04:09:29pm
This one is down the road from me, is it the right spec? http://www.ebay.co.uk/itm/T3-T4-Turbocharg...=item2eb2ea72c5 |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
8th Aug, 2011 at 04:38:00pm
they both look like chinese copies....
"Cars are a lifetime of pain" |
