| Home > Wanted > 3.5\" steel tube, short length/offcut | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
11th Aug, 2011 at 05:16:46pm
Don't suppose anyone has some 3.5" steel tube I can buy? I only need around 100mm of it. After about 1.5-2mm thick wall.
11th Aug, 2011 at 05:32:53pm
I've got some 3" 3mm wall tube, was going to put it through the sill on the van for the exhaust. On 11th Feb, 2015 robert said:
11th Aug, 2011 at 05:38:07pm
lol.... that is what I want it for. I have some tube but the wall is 4mm and too heavy/not enough room |
11th Aug, 2011 at 05:43:26pm
This is the right size for the job. Have 300mm if you want a bit.
11th Aug, 2011 at 05:48:51pm
I already have a 3.5" sized hole in the sill with a 2.5" exhaust ready to be welded up. Was trying to find pictures of metro challange exhausts but failed so just went for it! Edited by mayoturbo on 11th Aug, 2011. |
11th Aug, 2011 at 05:58:09pm
lol. Fair enough. How's about this:
11th Aug, 2011 at 06:08:58pm
On 11th Aug, 2011 apbellamy said:
lol. Fair enough. How's about this: http://www.ebay.co.uk/itm/290568108437 Would like something with a bit thinner wall if possible, I have tried to look on ebay but the rest of the length will just be wasted, got no other use for it |
11th Aug, 2011 at 06:13:38pm
You could roll some sheet steel up. On 11th Feb, 2015 robert said:
11th Aug, 2011 at 06:30:27pm
http://www.ebay.co.uk/itm/T304-Half-mtr-St...=item3a68806ac3 Crystal Sound Audio said:
11th Aug, 2011 at 08:20:30pm
Not sure if its any help, only pic I've got...
On 19th Jan, 2010 wil_h said:
432 Posts Member #: 7856 Senior Member Essex |
12th Aug, 2011 at 03:40:25pm
I have a bit of 3" stainless here if that is any good? wall thickness is around 1.5mm, there are 3 holes drilled in it that would need filling though! |
12th Aug, 2011 at 03:46:24pm
Got some sorted now thanks.
