| Home > Wanted > A+ Dizzy unit | |||||||
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
11th Aug, 2011 at 07:47:15pm
I'm after one of these, can be from any A+ engine, just need it for converting to a cam sensor, a la Paul S.
11th Aug, 2011 at 07:49:52pm
We have one in a scrap engine, from a 998 A+. It will cost you one pint of Santa Pod's worst lager. That's assuming you are there Saturday, otherwise £200000000. On 11th Feb, 2015 robert said:
11th Aug, 2011 at 07:52:05pm
Well i don't have £200000000 on me just now, so it'l have to be a pint i'm afraid :)
11th Aug, 2011 at 08:01:51pm
Pfft half a pint each! you don't ask enough andy! If something is worth doing, it's worth doing half of. |
11th Aug, 2011 at 08:31:12pm
I'll have the beer, you can get it out of the filthy old engine and put it in the van On 11th Feb, 2015 robert said:
11th Aug, 2011 at 08:53:56pm
On 11th Aug, 2011 Carl S said:
I'm after one of these, can be from any A+ engine, just need it for converting to a cam sensor, a la Paul S. Convert it my way, a lot better. (Hope Paul doesn't read this... :) ) Schrödinger's cat - so which one am I ??? |
12th Aug, 2011 at 03:23:15pm
Any chance of a link Rod? |
12th Aug, 2011 at 04:27:20pm
On 12th Aug, 2011 Carl S said:
Any chance of a link Rod? I did do a write up somewhere but I can't find it. Basically this, dizzy case machined down to next to nothing and an aluminium baseplate and aluminium slotted wheel added.
using an optoswitch instead of Hall (I like 5V)
and a nice neat cover (my cat likes it),
and giving this
Hall is probably best nowadays but I have an obsession about not letting 9-12V inside the case (irrelevant in this scenario as MS2 uses an opto isolator on the input anyway). Best solution overall is what Paul is now using, namely a Hall switch behind the timing gear (no dizzy drive required at all). Schrödinger's cat - so which one am I ??? |
12th Aug, 2011 at 05:00:03pm
Ah interesting, I already have a Hall switch but I think design could be adapted (a tooth instead of a slot, at 90 degrees to the plate).
Edited by Carl S on 12th Aug, 2011. |
12th Aug, 2011 at 05:12:06pm
I'm after one of these, can be from any A+ engine, just need it for converting to a cam sensor, a la Paul S. Convert it my way, a lot better. (Hope Paul doesn't read this... :) ) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th Aug, 2011 at 05:34:07pm
On 12th Aug, 2011 Paul S said:
Uh.... mine has done a few thousand miles ![]() Yes, but as you said back in 2009... On 11th Jan, 2009 Paul S said:
That's nice and compact compared to mine. I need to make another one for the Miglia although I'm thinking about putting it in the front cover with a tab on the cam pulley. I think that was the advantage of an optoswitch back then - I could make it a lot thinner. And your thoughts from over two years ago have come to fruition :) Schrödinger's cat - so which one am I ??? |
