Home > General Chat > Brake Bias Valve, screw in for more braking?
For the normal mini bias valve on the rear subframe, when its been converted what way is what? is it in for more rear braking?
I seem to be having a senior moment!
Lol Best PM nbooth660 as Nic had a similar dilema. It was a 50/50 choisce and he ended up overtaking the car infront and exiting the corner for the gravel pit backwards lol
He now knows exactly which way to screw the valve *hehe!*
The softer spring shuts off quicker, stronger takes more effort.
Righto, thts what I thought, bit couldnt remember what they looked like inside.
Just trying to get some rear braking to get through the MOT.
jimmy
Member #: 829
essex
what rear wheel cylinder you using do you no ?
1293 Turbo mini
34mm
jimmy
Member #: 829
essex
34mm ? do you mean 3/4"
On 11th Aug, 2011 Joe C said:
34mm
1293 Turbo mini
nope 34mm Kad calipers.
i always remembered right to rear,
meening screw to right for more rear brake,
Hard and fast will do it.
Not sure what direction that is though, or if it actually matters.
I'm not letting Hard and fast anywhere near it...
Anton
Member #: 764
Staffordshire
the one i made was tighten (in) for more rear... allways had to stand there at MOT winding the fucker in
