Home > Help Needed / General Tech Chat > Which Body Panels?
ntm1275
Member #: 9395
I need to buy a few panels for my new Clubman, so I need some advice on which ones to get
I intend to use as many Heritage panels as possible, but the ones that I need to know about are floor sections
My Clubman has a perfect rear floor sections, but the previous owner has bodged the fitment of new front floor pans which I want to remove and replace
From what I can see on the Heritage site, they do not do part floor panels, only full length 1/2 floor panels with sills for £205
Other companies make the part floor panels that I need, but I'm suspicious that these non original panels may be more trouble than their worth to get to match to the original floor
One of the companies that I have found with the panels I need is Mini Machine
Has anybody had any experience with Mini Machine non original panels, and are they a good fit compared to original items as the price is very attractive at £28.50 each, or is it best to just go for the full Heritage panel at £205, meaning a total of £410 for both sides (ulp!)
Any advice will be much appreciated
I put most of a hadrian front floor into my car. It wasn't a perfect fit. The flutes for the floors didn't line up perfectly, but otherwise OK. Pic's here:
http://www.turbominis.co.uk/forums/index.p...d=259072&fr=150
mini machine are the only non gen panels i would use
Tbh I would say that M machine panels generally fit better than heritage ones! Some of the heritage stuff is awfull! *oh well*
You really can't go wrong with M machine panels. For £400 you could get a full M machine floor.
Another vote for mini machine.
rick
ntm1275
Member #: 9395
I had heard that MM had good panels, but I just wanted to check with you Guys as I hadn't bought from them before
