Home > For Sale > Few random (mostly useless) bits i can take to mitp.
Have a few bits lying around im never going to use, so they may be of use to somebody?
Have a Pair of heavily smoked mk4 lenses, which were originally clear, attached to some mk4 light units which arent in the best of conditions and dont have wiring plugs on them, also have lamp to body gaskets, £5
HS4 Carb, reasonably clean, might want a quick strip and rebuild, has AAU needle, i think theres two spare throttle return springs and an abutment plate, £20
Three clock bracket and surround, the surround has been painted satin black and one of the black visor things falls out so its been taped in place, fine when its fitted, £5
7.5" blackstuff pads for 2pot calipers, barely used, have probably seen 100 miles at the very most, £5
Pair of rear spacered drums, some wear but dont look too bad, £5 (taken)
Standard airbox with reasonably new halfords air filter, £5
Just found the elbow for the air filter to hs4 carb, ill throw it in with the airbox.
Also have a hif44 airbox elbow, free to a good home.
I'll add anything else i can think of today, pictures upon request.
Edited by Carlzilla on 13th Aug, 2011.
Drums please!
Picture of the lenses, as theyre probably hard to imagine.
the.eliminator
Member #: 8323
Bedfordshire
Are the rear lenses still available? :)
Austin Mini Designer Stage 1 N/A 1098
Future build- 1275 with Gen' ERA Turbo setup
On 31st Oct, 2007 DemonPixie said:
Well I think you're all a bunch of nutters....
Yes mate they are, i have a few things i need to find out how much postage will be for so ill work it out hopefully tomorrow if i get back from work early enough.
