| Home > Help Needed / General Tech Chat > Changing turbo oil return - in situ | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
15th Aug, 2011 at 07:16:18pm
I think my return pipe is leaking...a lot, so i've just spent near on 30 minutes on my back removing it.
Edited by Simon on 15th Aug, 2011. |
15th Aug, 2011 at 07:26:27pm
I think doing it in situ is probably not the best option. I dropped the engine and subframe. It's not that much work really. It also means you can make sure the job is done properly. I even connected the battery to the engine and cranked it to check for leaks before refitting. |
15th Aug, 2011 at 08:28:26pm
Only 30 minutes, you've done well! On 11th Feb, 2015 robert said:
15th Aug, 2011 at 08:36:28pm
It's a pain to fit using a proper jubilee driver makes life alot easier. I usually just open the clips out as wide as possible. |
15th Aug, 2011 at 09:37:27pm
about the most difficult job to do i resorted to removing the drain from the turbo to change the pipe Yes i moved to the darkside |
16th Aug, 2011 at 08:22:42pm
Are you talking about the turbo return? Elbow etc? On 19th Jan, 2010 wil_h said:
16th Aug, 2011 at 10:08:31pm
if i still had an a-series i would be undoing the mounts, remove the downpipe, and pry the whole engine forward(with an old scisor jack), and get in there with a flexible jubilee driver. but rather you than me lol turbo 16v k-series 11.9@118.9 :)
17th Aug, 2011 at 07:12:56pm
Is a daft design. Why not just put the drain in the gearbox or flywheel housing?
17th Aug, 2011 at 07:17:14pm
I did. Into the gearbox. Doesn't make it much easier to get to though. It's just better downhill flow for the oil.
On 17th Aug, 2011 Jason G said:
Is a daft design. Why not just put the drain in the gearbox or flywheel housing? |
