Home > Help Needed / General Tech Chat > sincro hub question
c2_mad
Member #: 4215
hi guys
starting to reasemble my gear box, but i have a quick question.
im putting the sincro hubs back together, so i just want to make sure they are back together in the way they are supposed to. you can see in the picture that the iner part of the sincro hub on the left has a little lip, so my question is, is this lip facing the correct way assembled they way it is? also is the one on the right also correct?
thanks in advance for the help guys
c2_mad
Member #: 4215
can anyone confirm its on in the correct way?
c2_mad
Member #: 4215
just looked on the minispares website and seems like i put it on the correct way..
http://www.minispares.com/Product.aspx?ty=pb&pid=33204
would still like confermation from someone on here if possible.
Edited by c2_mad on 21st Aug, 2011.
you can build it up both ways but it will only fit in the box one way, fit the gearset, if it goes in were good :)
That does look correct.
c2_mad
Member #: 4215
thanks Vegard, just the confirmation i needed. can get on with the build now
