| Home > Help Needed / General Tech Chat > got her running but not the best?? | |||||||
286 Posts Member #: 4008 Senior Member near cardiff np12 |
19th Aug, 2011 at 05:41:03pm
took the mini out for a spin but it wont run unless the choke is out?
![]() 384 Posts Member #: 4215 Senior Member |
19th Aug, 2011 at 05:49:21pm
carb not set up properly? |
19th Aug, 2011 at 05:51:41pm
Well if it wants choke to run then that suggests that it is just too lean. If you have just started it everything probably needs setting up. Do you have an AFR sensor, that will tell you need to know? http://www.twin-turbo.co.uk
19th Aug, 2011 at 06:48:45pm
whats a afr sensor?
19th Aug, 2011 at 07:15:31pm
Air Fuel Ratio. Commonly called a wide band sensor.
19th Aug, 2011 at 09:47:49pm
its a 1310 no intercooler just running at standard psi.
19th Aug, 2011 at 09:51:57pm
i would suggest getting an afr gauge, there are 2 types norrowband and wideband, the wideband are 10x better but the price reflects, but it was the best £130 i ever spent. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
19th Aug, 2011 at 10:18:42pm
what does this afr gauge do? i have no idea with this turbo business im on a learning curve
19th Aug, 2011 at 10:19:52pm
19th Aug, 2011 at 10:58:03pm
like this
19th Aug, 2011 at 11:16:13pm
thats a narrowband,
19th Aug, 2011 at 11:59:52pm
no idea what that means but there you go
20th Aug, 2011 at 09:36:13am
Yes you will need to weld a boss into the down pipe.
20th Aug, 2011 at 10:10:13am
it boosts but it will only run with choke, no choke it doesnt rev well, as for timing i havent changed it since i bought it and it ran fine then |
20th Aug, 2011 at 01:57:50pm
Give it a good couple of turns on the mixture screw then and see if it improves. http://www.twin-turbo.co.uk
20th Aug, 2011 at 07:52:07pm
in or out? more or less fuel im guessing more |
1050 Posts Member #: 764 Post Whore Staffordshire |
21st Aug, 2011 at 01:25:28pm
screw it in for more fuel |
