Home > Technical Chat > Laser cutting 8mm Aluminium......
Jason G
Member #: 1459
En-suite user
Braintree, Essex
We are laser cutting some 8mm 5083 Aluminium next week at work. Is there everything you need that I might be able to sneak in? Normal beer tokens apply *wink*
Edited by Jason G on 19th Aug, 2011.
On 19th Jan, 2010 wil_h said:
Blank for the heater tap on the head please. can send you a steel.one to copy
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Or email a drawing Andy.
I'll have a go. will paint do...
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Basic shape with dimensions will do. I'll re-draw it and send back to confirm.
Perfect. I'll do it tomorrow and whizzed it across
Oooooh! Jason. I've got a high torque starter motor that has never fitted properly.
If I had a slightly modified end plate it could be made to work.
What sort of drawing do you need? I can put together an accurate PDF drawing if that's any good?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just a sketch with all important dimensions
998turbomini25
Member #: 2276
sheffield / derby
Sounds good! Fuel pump blanks might be worth doing?? I think there's a couple of other small things I could do with but won't be able to get measurements till Monday, when is the latest you need the drawings by??
cheers Luke
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just abit of 1mm mildsteel and gasket paper will do for that............*happy*
cheers Luke
998turbomini25
Member #: 2276
sheffield / derby
Ha, yeah I suppose it would *happy*
But you could drill and tap an ally one and make a custom oil drain for a Turbo?
cheers Luke
*happy*
Just had a measure up.
I don't suppose you do 12.5 mm ? Lol
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Nowt like moving the goal posts me old mucker!
cheers Luke
*happy*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
8mm to 12.5mm, are you still pissed from the weekend? Doubt we cut that thick to be honest.
10mm stainless is the thickest so far we have done. Takes alot more grunt to cut ally than steel. I think our limit for steel is about 20mm.
Sorry, saw the thread and posted before looking.
It might be easier to butcher the one I've got as it has a milled bit on the back too.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Let me know details of what you want, I'm sure I can help. May take some inventive wizardry
I know of someone who can water jet 12.5mm
If the machine says it'll do 12.5mm and you have never done any yet, I'd like to see how you get on *happy*
The bloke I use laughed at me when I asked, even though they advertise the fact. That said, they have replaced the mirrors recently and the performance has improved somewhat.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Don't know what our limit is for Aluminium and I can only get things cut from offcuts. 8mm Ally, 10mm steel/stainless steel is the thickest we've cut so far.
For 12.5, I was going to suggest 1 off 8mm, 1 off 3mm and 1 off 1.5mm plates and make the thickness up that way *happy*
Edited by Jason G on 20th Aug, 2011.
A friend cut some stuff for me with a waterjet. Thickest so far is 25mm aluminium. Pretty damn amazing really !!
That was the recomendation I had too. For ally and copper, use water jet.
The problem with aluminium and especially copper is that it reflects alot of the energy back at the mirrors. Consider that the mirrors themselves are made from copper, you can easily see why cutting copper is a problem with a laser *hehe!*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Too right! We were advised not to cut copper. Even ally we make sure its cut with someone there. Been known to catch the bellow etc alight!
What would happen if the material to be cut was polished to a mirror finish ?
Would the laser reflect off and cut itself ? lol
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Got quite a few people wanting parts cut now. I shall have to go legit with the govenor. Material will be free, but a small charge for labour. Will keep you posted :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Spoke to the boss today....so looks like a goer! It just Joe C kicking the arse out of the parts he wants! I am trying to wangle freebies!
