Home > General Chat > A little help needed with my gearbox
mini_mad69
Member #: 7048
Bridgend
I've tried to put my gearbox together (changing final drive and a straight cut first motion gear)
But i'm having trouble, I managed to fire ball bearings across the room with one box, and lock one gearbox in all gears or something.
So I was thinking, could someone local help/guide me put 1 good gearbox together out of the two, with my new parts. I can chuck to boxes in the boot and drive to your place.
I can fit a central oil pickup pipe and that's about it really.
I'm in Bristol or Bridgend.
Thanks
Ben
Edited by mini_mad69 on 20th Aug, 2011.
Turbo parts collector at the moment, almost ready.
Alex
Member #: 1851
Woolavington, Zummerzet
I'm a few junctions down the M5 from Bristol (just outside Bridgwater) and have done a few boxes recently if no-one closer can assist.
c2_mad
Member #: 4215
hi mate..
busy doing the same thing as you. this video has helped me a lot.
http://www.youtube.com/watch?v=tsOJPemcEDc
watch it a few times you and should be fine....
Flame Red
Member #: 6267
I'm in Bristol, I've done a couple of gearboxes before, it's been a while but I should be able to help.
These videos might also be of some help
