Home > Help Needed / General Tech Chat > Concerns with rear coilover bottom mounting
ntm1275
Member #: 9395
I'd like to hear from anyone who has coilovers AND rear beam fitted to the rear of their Mini
I'm concerned that the whole of the rear weight of the car will be put through the single small pin at the back of the radius arm
I have seen this snap on non coilover Minis before
Has anybody found this to be a weak point with coilovers or is it up to the job?
I will be strengthening the top mount, so no concerns there
Is there some kind on reinforcing bracket that can attached via the backplate bolts to help take the bending stress out of the mount
or
can you get a larger diameter pin (1/2 inch), but this also means having a larger bottom mount on the coilovers themselves
The Mini will be used on the road, so will get a pounding from the terrible road surfaces around my way
Any suggestions are much appreciated
turbominivanman
Member #: 1504
Westbury, Wiltshire
Never had problems with mine. Done 2800 miles in the van. No issues other than I have GAZ offset coilovers at the rear and needed to fit 11 inch 125lb 1.9in ID springs to prevent the KAD rear caliper from smacking the bottom drip flange of the wheelarch.
No issues at all with the rear radius arm pin. As it's for road use I'd stick with the standard pin on yours mate.
Richard.
Im sure KAD sell stub axles with a larger shocker pin.
Yep Kad do,
Ive got them on mine in case I ever wast to swap to coilovers, I just drilled the shock bush to suit, I think they are 3/8 rather than the std 5/16.
goes to look...
nope they are 1/2", and 3/8 std
http://www.kad-uk.com/mini-parts/spare-parts
You can always cut off the 3/8" pin, then drill and tap the spindle to take a 1/2" good quality bolt and drill out the bush on the coilover. Im sure you can buy the coilover with 1/2" bush anyway
I like that idea Paul, that'd mean you could remove a shock more easily without disturbing the radius arm.
ntm1275
Member #: 9395
@Joe C
I saw those KAD pins, but the website says they are for KAD's own alloy arms
@paul wiginton
I like that idea, and if one does snap it should be easy enough to change
