Home > Help Needed / General Tech Chat > power loss issue
eden7842
Member #: 8852
leicestershire
got a issue where at top end in 3rd and 4th i loose all power. i have to let off for 5seconds ish for it to return
if i let off and go straight back on it rele stuggles to boost back up. it barely makes it back to 8psi.
i dont think its fuel related as its just started and my aem stays normal.
any ideas? cheers
What happens when you let off for 5 seconds then put your foot back down? Does it do it again?
Does the engine hesitate or cut out completely?
If you're confident the fueling is ok, it could be the ignition. If you have any faults with the ignition, it will generally show up on load.
eden7842
Member #: 8852
leicestershire
when i let off, speed comes down (naturally) and then it works again.
its just a complete loss of power.
il check over the ignition and go from there, think it needs a damm good rr session
As it only happens at top end in tall gears I'd suspect that your float bowl is emptying.
If you have a prepump filter check it for flow. I've had one clog up, reducing fuel flow.
eden7842
Member #: 8852
leicestershire
scrap all that its running like a sack of shit in general. runs lean before boost, then perfect on for about 500 - 1000rpms untill it does the cut out thing.
just drove a 35min drive home which should of took 15.
Check your ignition and than do a compression test
eden7842
Member #: 8852
leicestershire
gunna do a comp test and having troubles checking coz my megatwat wont connect to the laptop atm
Sounds like fuel pressure to me from your post before last then.
You could try the T piece trick to confirm.
eden7842
Member #: 8852
leicestershire
just checked comp which is al fine.
and had the carb off and checked it all out and seems fine, should i still try the t-piece trick?
Yep! :)
eden7842
Member #: 8852
leicestershire
ok il try that 2moz, just to confirm. i tee the fuel pissover hole into the pressure pipe fro plenum, we?
