| Home > Wanted > male 5/8unf to female 1/8bsp (or similar) | |||||||
22nd Aug, 2011 at 01:03:48pm
my car doesn't have a servo so looking for a bung to go in the servo takeoff to use as a signal like for mjlj and dump valve etc. anyone have anything suitable kicking round?
319 Posts Member #: 1742 Senior Member essex |
22nd Aug, 2011 at 01:09:45pm
i made my one just got a correct bolt and had fitting. Drilled and tapped bolt and fitted the take off . i find getting unc/unf fittings hard to come by now Edited by jlay on 22nd Aug, 2011. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
22nd Aug, 2011 at 01:11:59pm
Don't be tight. buy the one at 4 quid and we'll drill and tap it On 11th Feb, 2015 robert said:
22nd Aug, 2011 at 01:12:21pm
Drill and tap an old water temperature sensor. The standard A series sensor is 5/8 unf. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Aug, 2011 at 01:14:36pm
They, or at least the hole in the head, are tapered On 11th Feb, 2015 robert said:
22nd Aug, 2011 at 01:15:29pm
It's not 4 quid it's more like 10. If something is worth doing, it's worth doing half of. |
22nd Aug, 2011 at 01:16:02pm
I happen to have a broken one of them!
On 22nd Aug, 2011 Paul S said:
Drill and tap an old water temperature sensor. The standard A series sensor is 5/8 unf. If something is worth doing, it's worth doing half of. |
22nd Aug, 2011 at 01:20:16pm
On 22nd Aug, 2011 John said:
It's not 4 quid it's more like 10. the one you mailed me this morning was 4 quid On 11th Feb, 2015 robert said:
22nd Aug, 2011 at 01:25:03pm
plus muchas delivery. If something is worth doing, it's worth doing half of. |
22nd Aug, 2011 at 06:59:37pm
On 22nd Aug, 2011 apbellamy said:
They, or at least the hole in the head, are tapered No they are not
22nd Aug, 2011 at 07:09:45pm
Excellent hydraulics guy here: 53.410554,-1.072349 (use google maps). You can just wander in and he has a warehouse full of pipes, connectors, fitting etc.. I use him a lot if I need stuff in a hurry. He's always happy to help even for little one off sales. Usually cheaper than Carlton. Mention Jamie the mad turbo mini builder and you might get a discount.. |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
22nd Aug, 2011 at 08:16:55pm
Try Think automotive or exact engineering.
