Home > General Chat > metro 998 FD ratio
can anyone tell me what a 1990 998cc metro final drive ratio should be? I can't find a definitive answer although I think it should be a 3.44
cheers
Rob
eden7842
Member #: 8852
leicestershire
from driving my mates id say 3.2
hazpalmer
Member #: 9038
Carlisle, Cumbria
3.2 is metty turbo i thought
Ben H
Member #: 184
Melton Mowbray, Pie Country
There is no definitive answer as far as I know. They were fitted with 2.9 and 3.1 as well.
http://www.twin-turbo.co.uk
jimmy
Member #: 829
essex
i had a metro 998 with a 3.1FD the car was a 1987
1293 Turbo mini
all standard metro engines got 3.44. The turbo got a 3.2 and a few parts bin specials towards the end of the production run and the economy models got 3.1. Vans had 3.6.
cheers guys.
Edit as Andy replied in the meantime.
Edited by Rob Gavin on 26th Aug, 2011.
jimmy
Member #: 829
essex
only the turbo run 3.2 FD
1293 Turbo mini
I've had one with 3.6
jimmy
Member #: 829
essex
and you can find a 2.7 FD as well
1293 Turbo mini
christ my head is fried now!
thought the 2.7 was only in the later coopers to achieve drive-by DB levels or something?
hazpalmer
Member #: 9038
Carlisle, Cumbria
count the teeth and work it out?
no 2.7's in a metro!
Have you got the engine number?
On 26th Aug, 2011 Paul S said:
3.647:1
Geek *happy*
not got the engine - there is a box for sale locally which is labelled as above - just wondering what the ratio would be to see if it is worth a bid or not
if unseen assume 3.44
wez
Member #: 9271
Stoke on Trent
as far as ive been led to believe all standard 998's after 88/89 had 3.44's.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
maybe I'll run a book on it!
3.647:1
Geek *happy*
1988 Haynes Metro manual that I forgot I owned and is now hanging up in the loo :)
Its pot luck Rob, but if its cheap enough its worth a punt anyway if only for a spare casing.
well if you include the Mini, the SPi Cooper has the 3.2 as well.
well, technically there were. Automatics had a 2.7 FD *wink*
He said Metro...
He didn't say manual...
