Home > Introduce Yourself > New to turbos - aim to supercharge 1330
rich89
Member #: 9576
Hi guy over from tmf
Going from only and every day comfortable 1330 mini to hopefully 1330 supercharged weekend warrior.
What mods do i need to read up on?
Hi mate welcome over, I would say the search on here is the best on the net.
Look up on turbos *wink*, personally for a weekend warrior depending on power i would start looking into the rotex supercharger instead of the eaton and sc12? Seems its pritty good personally done quite well on the twin cams so could do very well for a 5 port carbed. Or other side for lower power and quick response a gt15/gt17 turbo setup
rich89
Member #: 9576
will do. whats needed to happen regarding the gear box? will straight drops and x pin diff be ok?
alaskanow0
Member #: 8466
Mansfield
Welcome Mate, Id speak to a few people running superchargers before investing your money. Ive gone from supercharged to turbo for a number of reasons. I had a 1350 suckthrough Vmax kit with BMW charger, I found it very uneffiecent and limited to 120-130bhp, not to mension poor drivability, sub 20 mpg and starting problems. My turbo build is far superior, drives very nicly, good mpg and big power! If supercharging is the way you want to go look at some of the blow thru options or injection
Matt
rich89
Member #: 9576
its the bulk head mod that put me off but i think sub 20mpg does more lol
wez
Member #: 9271
Stoke on Trent
have a good read on here, there's exhaust manifolds you can use that mean no bulk head mods are needed. spend alot of time reading up before you spend money.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
alaskanow0
Member #: 8466
Mansfield
You dont have to cut the bulkhead, search mirage manidolds. Going Turbo could also work out cheaper.
wng691s clubby
Member #: 9252
Cleethorpes
welcome
Done now needs redoing lol
liam mini 35
Member #: 9125
Sheffield, South Yorkshire
Have you seen the slark racing blow through set up?
The turbo build has finally started
Hello and welcome
a suck through super charger is a dead fish.
blow through better .............but a well set up turbocharged set up is what to go for
Fortecphil
Member #: 7641
Jersey, CI
Welcome aboard.
