Home > Wanted > 2.18mm AP Verto Spring
Sometimes has a brown blob of paint on it.
Believed to be fitted to 998s. 1275s have the 2.45mm/green spring.
I'll take the whole clutch cover if you have it.
I'll check the 998 i have at yard at some point. Do you have a thicker one to swap with rather than buying?
Sure you got that the right way round? 998 brown, 1275 green? They are not the same as the pre verto colour coding.
Green - 998 - ??
Brown - 1275 - ~2.23mm
Dark Blue - Minispares - ~2.28mm
??? - Minispares uprated - ??
Light Blue - Turbo - ~2.54mm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4510
Not sure at all.
The two green ones I have are 2.45mm and are off 1990 Metro 1275s.
I also have a blue spring at 2.87mm !
almichie
Member #: 2065
I think blue are off the turbos - my blue one is off a turbo engine...
I have a998 witha verto fitted, I've yet together theflywheel off however. I need to get some heat on it in the next few days
Edited by almichie on 31st Aug, 2011.
Shaft seems nice and snug
On 31st Aug, 2011 Paul S said:
Not sure at all.
How are you measuring these? since the spring is not flat, using a micrometer without a pointed nose or, using the fat part of a caliper's jaw will of course make the measurement larger.
I am confident that the figures I quote, measured with a Mitutoyo digital caliper, and so far, its been proven 100% acurate to the 10th of a mm
