| Home > Help Needed / General Tech Chat > No lights conundrum | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
2nd Sep, 2011 at 02:24:29pm
I have spent hours trying to work out what the problem is but to no avail.
2nd Sep, 2011 at 03:04:01pm
have you checked the cable joints in the front panel? On 11th Feb, 2015 robert said:
2nd Sep, 2011 at 03:18:09pm
yes On 2nd Sep, 2011 Simon said:
I have disconnected the bullets at the front of the car and tested for voltage and there is none. However I get a positive continuity test between the red/green wire and earth. assuming thats the front panel you mean
Edited by Simon on 2nd Sep, 2011. |
2nd Sep, 2011 at 03:52:41pm
Could possibly be a faulty relay, best to check with a known working unit if you dont have a spare or dont want to buy one straight off, id also check the functionality of the stalk switch just incase by disconnecting the wiring plug and continuity testing it :)
Edited by Carlzilla on 2nd Sep, 2011. On 26th Jan, 2012 Tom Fenton said:
2nd Sep, 2011 at 04:16:23pm
i've checked all the fuses with the continuity test but nothing further.
2nd Sep, 2011 at 04:23:07pm
Have you tried just putting a +ve wire straight from the battery to the back of the switch? Does this make your lights work? Sounds like you have a high resistance supply to me? http://www.twin-turbo.co.uk
2nd Sep, 2011 at 04:28:28pm
my first port of call would be the fuse box. I've had no end of issues in the past with bad and poor connections due to corrosion |
2nd Sep, 2011 at 05:09:43pm
On 2nd Sep, 2011 Ben H said:
Have you tried just putting a +ve wire straight from the battery to the back of the switch? Does this make your lights work? i've not tried this, i like your thinking. although i just tested the power to the brake test swicth (which lights up fine) and the voltage on that drops to zero when i test with both the multimeter and lightup screwdriver at the same time. the fuses and connections to them are ok, this is a recent fresh built car with 1000miles on the clock there is no corrosion. |
2nd Sep, 2011 at 05:12:17pm
corrosion could be in the fuse box - not in the car itself. I've had issues with the back of the fuse box in the past. There is enough connectivity to let the test light work but as soon as you load it up, it looses continuity |
2nd Sep, 2011 at 05:53:03pm
I shall partly appologise Edited by Simon on 2nd Sep, 2011. |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
2nd Sep, 2011 at 05:58:13pm
have you got high powered lights in, could be that? remember there built for sealed beams! "Cars are a lifetime of pain" |
2nd Sep, 2011 at 06:00:38pm
their the wipac quadoptic halogen's |
2nd Sep, 2011 at 10:09:23pm
I just check around the loom wherever possible looking for something that could have potientially earthed out but not taken the fuse. A faulty bulb may have caused this, ive known blown lightbulbs do all sorts of funny things. On 26th Jan, 2012 Tom Fenton said:
