| Home > Help Needed / General Tech Chat > Rich on cruise | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
4th Sep, 2011 at 05:39:48pm
Been out today and done 150miles, mainly A roads and dual carriage ways. At 55-75mph on cruise the AFR is showing between 10:1 & 11:1, on very light throttle it just staying at 10. My lean off pipes connected and not block. Other wise the needle seams fine everywhere else. I've profiled the needle from a BDD, and currently get 11.4AFR @ 8psi, 11.8AFR @ 12psi & 12.2AFR@ 14psi. Cruise under 50mph is ok at 14AFR. Throttle response is really good everywhere. Idle is 13AFR. I've not done any work on the cruise area of the needle. Using 20/50 for damper oil and yellow carb spring. Any ideas?
Class C 3rd Place Avon 2011 14.18 @101mph |
4th Sep, 2011 at 07:33:48pm
Mine is the same on cruise. But my part throttle pipe is blocked off.
In the 13's at last!.. Just |
